8
82125
So i thought i could just walk in to the local solar installation place and get another solar panel, charge controller and 2 new bigger AGM batteries fitted..
Apparently not. On my Burstner Elegance i890 it has the Schaudt EBL220 -2 (link below)
EBL220 manual
Everything, including the solar charging, goes through this unit. Everything is done by this unit including all the charging whether from 230v, alternator or solar, and the maximum solar charge it will allow is just 14amp (fused at 15amps), I was planning to add an extra solar panel (200w), a 30a Victron controller and upgrade my 2 lead acid varta 90ah batteries to 2 150ah AGMs.
The EBL doesnt allow AGM's either, it says wet lead acid or dry batteries only. (selector switch only has 2 positions, presumably reducing the charge when set to gel).
So it seems i cant have AGM's, cant put a decent amperage solar controller in (to run the existing 150w+ and a new 200w solar panel), and then the next problem this causes is "the 10% rule of thumb" having a charging system capable of actually charging the available battery capacity.
If i put 2 x 150amp batteries in I would need the 30amp Victron controller in order to maintain the 10% rule (but the EBL has a max of 14amps which i read as meaning i shouldnt upgrade my batteries must past 140ah combined). Or am i confusing amp hours with amps here??!
I guess i could fit a 10amp charge controller (do they even make 14amp controllers that my EBL maxs out at?), but that would make it a bit pointless fitting an extra 200w panel if my EBL can only put 14amp max in to the batteries?
Its all got very confusing, can anyone help please? or know where i can go that specialises in these Schaudt EBL systems and can fit the upgrades Im looking for?
Thanks.
EBL220 manual
Thanks.
