Sog vent leaking on roof of n+b smove. (1 Viewer)
Aug 27, 2018
201
304
Lancashire
Niesmann and B Smove
Since 2018
Took our 2018 smove back to travelworld today to have a few jobs done under warranty as we have only had it 3 months.
On the way someone kindly pointed to our bedroom skylight and said it was flapping open we shut it and asked the technicians to check for any issues when we arrived at Stafford.
Thankfully we did , as they noticed a wet patch on the ceiling which is lined with pads , wet not damp !
Later on in the day after they had fixed the other defects they told us it was the sog pipe filter in the roof that was leaking and this had caused the water ingress into the habitation ceiling.
Firstly I had no idea the sog filtered out of the roof and that it was a potential leak hazard.
On looking up sogs I queried if indeed there was a sog why I had never heard a fan when the toilet is in use as most appear to have one.
I was told I have a half sog 🤷‍♀️
So my question is really this , is this a common occurrence? why would you have a hole in the roof for venting that will also allow water in ?, is the damp which is now in the ceiling always going to be a problem ?
We were supposed to leave for the alps on Saturday but were advised against and to bring it back in December for a week.
To the member of staffs credit she could see our dilemma and dispatched us home in a Fiat panda with the promise they would try to fix it or bodge it by Friday.
Any thoughts please ?
WESTY66
5,812
14,248
South Yorkshire
Carthago Chic C-Line
All the gear, and no idea!
I’m sorry, I can do nothing but wish you a great time in the alps, enjoy, hope everything works out for you🤞👍👍
Minnie
Aug 27, 2018
201
304
Lancashire
Since 2018
Thanks for your concern and good wishes. Much appreciated
Oct 30, 2010
4,256
20,707
Suffolk or France or ........
A Class Carthago Chic
Since 2008
Surely you either have a SOG or you don’t.
Never heard of a 'half SOG'.
You should have a flexible pipe connected to your cassette which runs up to the roof via a fan.
It's only air that goes up the pipe so if there is water ingress it must mean the small outlet ‘chimney' hasn’t been fitted correctly.
Richard.
Minnie
Aug 27, 2018
201
304
Lancashire
Since 2018
Richard.
Yes wasn’t sure what a half sog could be. Was told there is no fan.
Apr 26, 2015
2,768
6,893
Ottershaw
Hymer S820
First motorhome May 2021
My Hymer has a vent to the roof but no fan, you have to pull the corrugated pipe off the cassette before you can remove it. But no leaks so far, touch wood.
Minnie
Aug 27, 2018
201
304
Lancashire
Since 2018
Thanks for that info. Probably the same with ours then.
53,417
149,916
Typical useless TW, roof outlet SOG's don't have a filter, the fan will be in line with the pipe probably behind a cupboard back. The fan isn't much bigger than the pipe diameter.
The leak sounds like the roof vent hasn't been fitted correctly.
53,417
149,916
Hymer don't fit roof vented SOG's unless you did it yourself like I did.
WESTY66
5,812
14,248
South Yorkshire
Richard.
Hi Richard, does yours have a SOG? Just curious as mine has one which runs up through the roof and wondered if it was a Carthage thing or the previous owner has fitted it, and yes there is a fan which fires up when you move the blade👍
Jun 10, 2010
8,507
20,218
Shrewsbury (sometimes)
N&B Clou Liner MAN
Our N&B Arto had similar but also had an inline fan. But yes the bit to the roof is basically a little chimney, hard to see how it could be in wrong unless they re also using lighter sealant these days.
Apr 26, 2015
2,768
6,893
Ottershaw
Hymer S820
Well i guess a previous owner could have fitted it but it looks like an oem fixture to me, and unless the fan is in the roof it does not appear to have one.
Oct 30, 2010
4,256
20,707
Since 2008
Yes, standard fitting on the C- Line.
The fan is behind a panel in the corner cabinet in the washroom.
