- Oct 13, 2016
- 631
- 496
- Mercedes Hymer B680
- Been moho’ing for a time now
We have the Status 315 aerial installed, works perfectly outside the house, but generally not that well on most sites ??, so after severe amounts of TONGUE pie instructions were received from SWMBO GET A GOOD SATELLITE RECEIVER, we already had an ALDI satellite which is fine, apart from the setting it up at each different site (Grrr).
So I looked around and settled on the Snipe 3, fully automatic satellite;
Since fitting the Snipe 3, no more tongue pie, just about 750 channels (about 350 no pay), it takes a few minutes to find the respective satellite (it's controller comes with 9 programmed satellites and 3 spare user channels). You install the mounting plate to the roof, then the satellite just mounts straight onto the plate, followed by the wiring, the kit comes with a roof seal box to enter the van. Also incorporated in the system is a white wire that you connect to the ignition (i connected ours to the 12v fridge connection) so if you forget to lower it (back home) as soon as you start the engine it returns to its home position and locks in position.
Fitting, fairly easy, I fitted the mounting plate one day, allowed the silicone seal to set and finished the installation the following day,
SUPERB, works a treat, highly recommended. Price, I seem to remember was about £650.00, delivered from Amazon.
the first 2 pictures is the Snipe installed, pictures 3 & 4 are when it's up and working.
BY THE WAY THE SNIPE 3 DOES NOT COME WITH A RECEIVER, JUST THE SATELLITE SET UP CONTROL BOX, another review to follow for the receiver.
