Snipe 2 problems with locking onto astra 2 (1 Viewer)
Nov 23, 2009
29
5
Bracknell
Bessacar E465 2006
Since 2009
Hi all sorry to bother you all with yet another snipe problem It will find astra 2 for a couple of seconds then goes into fine tune mode then it looses it then goes into other sat
I would like to turn off fine tune but can't see how to do it in the book does anybody know how to do it
Also if the type c control box is needing to go for repair can anyone recommend a repair company
Very many thanks for replies in advance
StanandShirley
415
491
Chatteris Cambridgeshire
Chausson Titanium 640
four years
Having the same type of problem, got an update but needs a usb connection which ours doesn’t have. Also looking for somewhere or someone who repairs Snipe systems so hoping you get yours fixed and any information would be helpful
Dec 16, 2015
81
118
Suffolk, UK
Van Conversion
10 years
I had the same problem last night from Northern France. It eventually locked on ok to 28.2.
Haven’t tried doing the update yet as didn’t want to risk making things worse while I am away.
Lenny HB
53,309
149,502
On the coast in West Sussex
Hymer B678 DL
Sounds like a Snipe one, you do the update via a program you download from the Snipe site and connect your pc via a usb A to Be lead. The software needs XP it won't run in later operating systems.
Lenny HB
53,309
149,502
Hymer B678 DL
If not looking on to Astra 2, try turning to Hotbird and if it locks on them change to Astra 2 it often works.
If it locks on but picture pixelated you can fine tune manually.
lorger
9,655
90,485
Dumfries
Knaus Sun 650MEG
This has happened on the odd occasion with ours, we just find Astra 1 then try 2 and it locks on all the time. Will look at the update.
Sep 11, 2016
229
170
nottinghamshire
newbie
I know its an old thread, but I am having similar problem and I have updated software but its still happening ,finding sat for a few seconds then going on to look for other sat.then Repeating
Two on Tour
10,304
50,722
Elddis Autoquest 175
Since 2010
Ours did this when it was still under guarantee, so returned it to the supplier and it in our case it was a cable to the LNB internally that had broken. They repaired it, sent it back to us and it has worked fine since.
MisterB
5,839
13,058
Essex
Adria 670 SLT
is it worth trying the update again?
Gellyneck
9,195
18,142
Scotland
More than toes wet now!
Are you waiting for the blue GPS light to stop flashing before starting the search?
Dan and Jan
572
4,524
Scotland
Between Vans
On and off since 2000
Sounds obvious but have you a clear line of sight. Can’t get mine to lock on my driveway for that reason.
Gellyneck
9,195
18,142
Scotland
Have you checked the controller connecting wire (think it's the black one from memory) connection to the dish base?
Think the black and grey coaxial wires may be interchangeable (better check though). Is it worth trying to swap them over to see if the dish then aligns? If it does and you get no signal on the TV it may be the controller wire is faulty.
If it still doesn't work think it then points to either the dish or the controller.
What version of firmware is on the controller?
lorger
9,655
90,485
Dumfries
Knaus Sun 650MEG
We struggled to find Astra 2 a few times and alway found if you search for Astra 1 first then 2 worked every time for us.
Sep 11, 2016
229
170
nottinghamshire
newbie
it finds astra 28.2 but instead of locking it says check other sat and off it goes then comes back to 28.2 again , when it finds it tv works ok for a few seconds then off it goes to search again. not at van so cannot tell what firmware is running at moment , the latest update on selfsat site is 19 0ct last year
Lenny HB
53,309
149,502
Hymer B678 DL
I had a Snipe 1 on my last van that did that, when it found 28.2 I would turn it off as you can use the Snipe with the power off.
May 19, 2018
246
389
Are you downloading the update from a page that looks like this?
I've been having similar problems with the controller constantly "searching oth sat". I just updated using the download from www.selfsat.com and now it is locking on. Previously it never got as far as "checking", only fine tuning.
The version I have is snipe2-V20022
I think it has extra messages on the controller when it's finding the satellite and tuning in now. 15897177196673349223574362667586.jpg
Sep 11, 2016
229
170
nottinghamshire
newbie
yes I have dated 19th oct last year, its 2.5 years old bought from Germany , don't know weather to buy a snipe 3 and do a straight swap or bit the bullet and spend £1500 on a better system. I went for snipe 2 just for convenience in uk and northern France, but deep down I no the quality is not there with a snipe . I know I can use data for tv but in Europe 15 g isn't going to get me much tv.
The service and repair of snipe seems to be nil in uk cannot find a thing on the internet regarding repairs , so if I buy another in 2/3 years will I be in same boat.
