SMEV OF311SG OVEN
Nigelw
North Wales, UK
Hobby Van Exclusive
I'm a newbie
Hi. I have a Hobby Van Exclusive with the above oven. I have a problem with the fan coming on for no apparent reason when I'm not in the van. I'm worried it will run the battery down if I dont check on it regularly.
I took it to the garage under the warranty, and they said they don' have fans! ....so what is coming on??
Has anyone else had this problem and know how to sort it? (There is definitely a fan as it comes on when I light the oven)
could be a possible extractor fan above the oven!
switch off the main habitation 12v supply switch on your panel that should eliminate it coming on and running your battery flat.
but as you say you need to find the reason why its coming on.
