gerry mcg
I've noticed a small (200mA / 0.2A) current drain being recorded on my BMV700 that appears to be happening when all power is off on the van since I have had my lithium batteries installed along with a Votronic VCC1212-50 B2B.
I can't think what could be causing it, but I wondered if it is perhaps the VanBitz Battery Master taking a little bit of current from the lithium battery that is sitting charged at 13.4v and passing that to the Starter battery (rather than the lower voltage of the old AGM Leisure battery at 12.9V to 13.0V) as there is now sufficient voltage differential between the lithium battery and the starter battery
I have now got a victron Smart battery Sense fitted to the lithium battery to provide temp data to the victron MPPT, but that should only draw 20mA, so 1/10th of the noted currently draw.
Edit. The BM light is red, that indicates there is current being drawn
Any thoughts?
Any thoughts?
