Slight smell of gas - is it normal? (1 Viewer)
Fletton
1,531
2,501
Lincolnshire, UK
Knaus Sky I Plus 650LG
First MoHo - April 2015
Hi Guys n' Girls
Occasionally i can smell a very faint whiff of gas when I'm sat in the drivers seat - and parked up....
The Gas locker is immediately to the right of the driver's seat below the window.. Euro Shell on UK chassis..
I've sprayed copius amounts of " Gas leak" spray on and around the fittings in the locker.. and the flexi pipe too - with no visible bubbling etc.. I note the hose - sorta stinks anyway....
Should I investigate further?... Or is that very feint gas smell normal....
I do have a sensitive nose... !
DBK
18,022
48,089
Plympton, Devon
PVC, Murvi Morocco
... is that very feint gas smell normal....
No! But are you sure it is gas? It might be for example the smell of rubber.
If you can't find it take it to someone with kit to locate it. It might be the pipes have become porous and need replacing.
JeanLuc
3,304
2,199
Warwickshire
Hymer B630 Star-Line
No it is not normal. The gas bottles and associated pipes, valves and regulator should not emit a smell of lpg, other than when changing / refilling depending on what installation you have. I would get it checked by a fitter if I were you - assuming you still cannot identify the culprit yourself. If you have not already done so, it might be worth fitting new washers in the connectors in case one of those has failed.
Fletton
Fletton
1,531
2,501
Lincolnshire, UK
I'd say deffo a gas smell.... Been around in the game long enough to detect that smell...
I think I will... Although it's a new van!... But if its not norm... then there is deffo a tiny teensy weeny leak.... somewhere in or around the locker...
scotjimland
2,309
9,979
A Woosh bang
Is there a battery under your seat ?
If so it could be Hydrogen Sulphide gas.. similar smell to LPG
Fletton
Fletton
1,531
2,501
Lincolnshire, UK
These being specifically what and where... in what connectors.... :)
Flexi pipe washers.... olives?.... Gasket type?
Fletton
Fletton
1,531
2,501
Lincolnshire, UK
Nope!... deffo gas locker... or pipework as it enters somewhere there...
and I can tell the difference :)
Fletton
Fletton
1,531
2,501
Lincolnshire, UK
Anyway.... No worries.... As long a very feint smell in not norm... I will get to the bottom of it... by hook or by crook....
Thanks peeps :)
scotjimland
2,309
9,979
A Woosh bang
if coming from the gas locker, it's strange you can smell it in the van..
if it were a leak in the locker the gas would fall out the vent in the bottom.. not rise to the hab area.. which should be sealed from the gas locker..
is it not coming from within the van.. a cooker control knob, gas manifold valve etc ?
Fletton
Fletton
1,531
2,501
Lincolnshire, UK
Don't think so.... I can only smell it from driver seat area... Which like i said ia adjacent to locker....
Also... A breeze may make a difference .. To it falling!?...
JeanLuc
3,304
2,199
Warwickshire
It depends on your system. I have a Gaslow refillable and there are flat washers in the unions with the bottle valves. If you use Calor, the connectors may be different, I'm not certain. I would check them all.
scotjimland
2,309
9,979
A Woosh bang
might fall sideways.. :LOL:
seriously.. go over all the joints , vales and connections again with leak detector liquid.. or water with a small amount of washing up liquid..
it's easy to miss a bubble.. and it only needs the tiniest of leaks for it to smell.
The gas system should be pressured checked at the hab service and any loss of pressure rectified.. .. unless you do it yourself..
TheBig1
17,630
43,252
my mrs was sure we had an lpg leak last year. I checked everything, including a pressure drop test, nothing at all found. Then one of the dogs farted and she said.....theres that smell again:banghead:
Fletton
Fletton
1,531
2,501
Lincolnshire, UK
Well i've had my nose in the locker ... And not a bean!...
Had my nose around the "offending area"....
I'm coming to think it's just the smell of whatever material is in that area... When the sun gets on it.... Combined with an oversensitive nose... :)
TerryL
6,180
8,180
North East
Low Profile
In fairness I thought I had a gas leak at the Stratford Show last year but couldn't find it. So I got Ash to do a test and it came up no problem. Suppose it could have been one of the ideas floated above!
But the important thing is LPG CAN BE DANGEROUS. Get it checked out if you're unsure.
vwalan
Sep 23, 2008
8,835
5,798
roche cornwall
lynton5th wheel
since a child
must admit i like bottle top regs . if i think theres a leak i can remove the reg connect a foot pump with a guage and pressure the system .open and close each of the gas lines from the gas manifold .
mind fitting one of these is ideal.
