Sliding side indows (1 Viewer)
Jan 31, 2016
1,897
3,372
Alness, Cromarty Firth
Hymer B544 (2012)
newbie
Not sure if this a particular Hymer problem or general to all A class.
The sliding window on our B544 runs in a rubber/felt type channel, in the rain this gets wet as the rain runs don the window and seeps into the channel. This doesn't seem to be a problem as there are drain points.
The problem I'm having is the channel dries out and then get dragged by the window when I slide it open, I can pull it back but it's getter out of shape bit by bit.
Any suggestions ?
Dec 2, 2019
3,578
7,737
Amersham
van conversion
Since 2019
PTFE spray, so the gasket it does not stick to the slider.
Jul 4, 2018
1,197
1,571
Bristol
Weinsberg
A few years.
Replace it the felt is wearing out and the glass sticks to the rubber. Common problem on early Minis look on ebay for replacement.
Sep 4, 2020
165
409
Chester
Hymer S630
Since 2018
We had a similar problem, silicon spray has solved it for now until I have the time/inclination to replace it!
Lenny HB
53,224
149,280
On the coast in West Sussex
Hymer B678 DL
I expect the rubber has hardened with age best to replace, as others have said silicon spay will give temporary relief.
Jan 28, 2008
10,111
18,303
Dovercourt, Harwich, UK
Renalt burstner
7 years campers before that
ive got similar problems on my burstner but i can see no way to change the felt runners as they appear to be cast in place when the window is made
