Hymerbell
- Apr 2, 2014
- 1,112
- 2,583
- Hymer 674
- Since 2002 plus 20 years in a tent
You use a hair dryer ?....which hair do you dry first ?Having owned one, it would have to be a long holiday...
Yes mostly on yer back...Unlike many men my age, I need a mains powered dryer to cope with my luxurious locks...
Gosh! I didn't realise we were that close...Yes mostly on yer back...
Actually just seen your avatar....you’re right....very luxurious ? you must need a powerful inverter.Gosh! I didn't realise we were that close...
Easy enough to fit but can be difficult to get the batteries you want and much more expensive, batteries are one thing that are cheap in the UK.
Depends on the model of the fridge most these days have electronic control so if your batteries fail no fridge, same with heating.
It would be unlikely for both batteries to fail totally so you could probably get by but it would be cheaper and easier to replace them in the UK.
Ah right...well I’m reluctant to just ditch the Banners as they look pretty new. If I went for the cheap car battery option would it just be a case of attaching negative terminal of first battery and positive Terminal of second battery As I would only be buying one car battery. Would it last a couple of months if I didn’t use a TV or inverter.If the batteries fail completely, you could buy a cheap car starter battery which will run the fridge, lights, pump and step perfectly well until you get back. If the weather's good you could get by on that, but you'll have to cut back a bit on extras like TV and inverter.
You worry too much ? use them until knackered. You can always disconnect one, or disconnect both and use the engine battery temporarily, like I did ?Ah right...well I’m reluctant to just ditch the Banners as they look pretty new. If I went for the cheap car battery option would it just be a case of attaching negative terminal of first battery and positive Terminal of second battery As I would only be buying one car battery. Would it last a couple of months if I didn’t use a TV or inverter.
That's about right. Lots of people who just tour in summer and have low demands on the battery manage perfectly well with just a single car battery and a bit of solar. The extra capacity is only required if you want all the modern electrical conveniences, which understandably many do.Ah right...well I’m reluctant to just ditch the Banners as they look pretty new. If I went for the cheap car battery option would it just be a case of attaching negative terminal of first battery and positive Terminal of second battery As I would only be buying one car battery. Would it last a couple of months if I didn’t use a TV or inverter.
