Sika Adhesives (1 Viewer)
Top Hat
375
643
Durham
Van Conversion
8years
I've been talking to sika technical dept asking for their recommendation for fixing a solar panel using adhesive only to a PVC, They recommended that the area to be treated first with Sika Activator (not cheap) then to use Sika 552 adhesive
I have seen various adhesives recommended on here and by company's supplying panel mounts but never seen any mention of Sika Activator.
Is this because there's a cheaper method out there?
Charlie
scotjimland
1,437
5,209
UK
Timberland
I posted this on the other thread..
https://www.motorhomefun.co.uk/forum/threads/solar-panel-blown-off-roof.186806/page-2
my Alden AS 4 Auto Sat dish was supplied with
Sika 252 + Sika Akitvator
There is no mechanical fixings or screws to hold it to the roof.. it has been on for over 3 years ..
this is the procedure,
instructions by Alden
Sika 252 for fixing sat dish or solar panels.
  1. Use a pencil to mark the place of the unit on the roof.
  2. Sand the roof surface with sandpaper.
  3. Clean each surface with a thinner.
  4. Spread Sika-Aktivator on the sanded surface.
    Leave to dry for 15 to 20 minutes.
  5. Glue generously the base of the unit with SikaFlex 252 then press slightly on the unit. Layer of glue: ± 3 mm.
  1. To accelerate the polymerisation, spray a little water on the visible parts of the glue.
Leave to dry for 24 hours.
The full instructions on how to fit the solar panel can be downloaded from here
https://www.vanbitz.com/wp-content/uploads/Phoenix-mounting.pdf
Steve N Tracy
1,194
4,651
Southampton
4 Years
According to the American safety sheet the 205 activator is mostly isopropanol avaliable off ebay very cheaply, I have used isoprop to clean and degrease the roof before fitting 4 solar panels and 2 satellite dishes with 252 and non of them have come off.
Oct 29, 2016
4,372
47,981
Surrey
Carthago C Tourer
This has been done to death on another thread that is still going!
I did as it said on the MH Fun Tin at the time.
I didn't use the activator (although I had heard of it), I did everything as suggested in @scotjimland thread , but without the activator. I used the Sika 552, for the ABS panel brackets, and I used mate Stainless Steel Self Tapping screws, all of which would now appear to be wrong advice:eek:
The Solar panel is large, held on with 6 brackets also large, it is not screwed to the roof, but so far it has stuck like you know what to the proverbial.
I will of course be checking all is OK on a regular basis, but no I aint screwing nothing to the roof.....yet:whistle:
Les
PS: even Photonic Universe that supplied the panels said "We just use the ABS Brackets and SS self tappers":unsure:
Well I will go to the foot of my stairs as they say
scotjimland
1,437
5,209
UK
Timberland
that's interesting, and not disagreeing.. nor wishing to debate but this is what the Sika Akitvator safety data sheet says https://www.google.com/url?sa=t&rct...ktivator.pdf&usg=AOvVaw3_J__r_7BTxEZzT0_h3ny0
Ingredient name
naphtha (petroleum), hydrotreated light 50 - 70%
heptane [and isomers] 25 - 30%
ethanol 5 - 10%
Tris(dodecylbenzenesulphonato-O)(propan-2- olato)titanium 1 - 3 %
Google any of the Sika products and you will find the product information, application and uses
Emmit
7,764
16,977
Cornwall
Burstner A Class
Jan.2014
********WARNING***********
INCOMING "STUPID" QUESTION
After you've marked the position of the roof with a pencil, doesn't using the alcohol make the pencil disappear.
(I'll try at this point to recover my position?)
Or is the pencil marks merely to position the rubbing of the abrasive?
Sep 16, 2013
2,214
7,703
Horncastle, UK
Van Conversion
Since 2006
I used as recommended (552 + Activator) on my solar panels and awning bracket.
There's often pretty good deals online buying the two together.
Two on Tour
9,756
45,714
Elddis Autoquest 175
Since 2010
I use masking tape. I set it out 3 or 4 mm wider than the mount to allow for a fillet of adhesive as you would do say sealing a bath or sink.
This will allow you to scuff the area to be bonded without marking areas of the roof you want to keep pristine.
Having stuck down your mounts you can remove the excess adhesive to the masking tape and when you remove the masking tape you have a nice neat finish to the edge of the adhesive.
mfw
Banned
Sep 16, 2017
1,224
508
Worthing
If you follow sika instructions and you use what they suggest you should not have problems - most important part is going to be preparation if it is not properly cleaned and prepared you could have problems and probably will
Top Hat
Top Hat
375
643
Durham
Van Conversion
8years
Les
I'm doing something a little different so want to make sure I get it right, a PVC roof is slightly corrugated running from front to back, I have not enough room to fit the panel with the corrugations so it has to be fitted from side to side meaning the .685 spoiler mounts I am using have to hit the high corrugation, it took a lot of looking to find a panel + mounts that hit precisely on the 70mm wide high corrugation.
Louis
1,201
982
Anglesey
Fiat Ducato Auotrail
6 Months with motorhome(35 years tugging)
How do you get ± ..... no sorry only jokin man :ROFLMAO::D(y)
scotjimland
1,437
5,209
UK
Timberland
Lenny HB
50,273
138,855
On the coast in West Sussex
Hymer B678 DL
When I read the Sika info it said the activator " may assist withe the adhesion" at over 30 quid a bottle for the activator for 292i I didn't bother.
scotjimland
1,437
5,209
UK
Timberland
Lenny HB
50,273
138,855
Hymer B678 DL
Top Hat
Top Hat
375
643
Durham
Van Conversion
8years
Northernraider
25,903
153,345
On the sofa ....
Hymer 654
On and off since 95
I used sikaflex 512 for my panels didn't use anything else
Worked
scotjimland
1,437
5,209
UK
Timberland
Worked
not recommended for fitting solar panels..
your choice.. >>
Sikaflex®-512 Caravan is a strong elastic adhesive that bonds and seals in one operation. It is purpose-designed for building and repairing caravans, motor homes and trailers and does not suffer from the problems of traditional mastics.
Correctly installed, it will provide many years of leak-free, and trouble-free service.
Roof vents, skylights
TV aerials
Awning rails
Lap joints
Butt joints
Fillet/corner joints
Window strips
Leaky gaskets
https://www.google.com/url?sa=t&rct...0Caravan.pdf&usg=AOvVaw0HpE0FrM1DAj4U2oyLlYf_
Top Hat
Top Hat
375
643
Durham
Van Conversion
8years
At Asda you can get 1000ml of vodka for £16, probably do same job and 750ml left to celebrate with after.(y)
Yeah it might very well work but, is it worth £16 to take a chance and not follow the recommenations given and have it not work, if I hadn't looked into it I may have just used adhesive but I did so to ignore it would be stupid.
Good idea to celebrate though :confused:
Charlie
Northernraider
25,903
153,345
On the sofa ....
Hymer 654
On and off since 95
your choice.. >>
TV aerials
Awning rails
Lap joints
Butt joints
Window strips
Leaky gaskets
https://www.google.com/url?sa=t&rct=j&q=&esrc=s&source=web&cd=2&ved=2ahUKEwjv8Mrnht_eAhVlJsAKHVZZCn8QFjABegQIABAC&url=https://svn.sika.com/dms/getdocument.get/b15d3e51-9d43-31b7-bbb3-b9abe2d374a0/B%20Sikaflex%C2%AE-512%20Caravan.pdf&usg=AOvVaw0HpE0FrM1DAj4U2oyLlYf_
It's what the supplier of the panels I fitted reccomended and I fitted them over a year ago covered 18000 miles in all weather's , withstood very high winds and speeds up to 80mph.
Were still as firmly glued to the roof when I sold it as they were the day I fitted them.
138go
3,276
14,612
Carthago 138
Since 2001
I glued my Snipe 2 down with Sikaflex 512 and I noticed the other day that it is still there. I did use three of the little silicon rubber stops that you get on kitchen cupboards to give me a gap for the Sikaflex.
