cmcardle75
I'm having some issues with my new water installation. It uses a 30psi 10.6lpm Shurflo Trail King 10. All pipework is new. It is run in a mixture of 15mm domestic pipework on the inlet side and 1/2" bore reinforced food grade hose on the output. Outletwise there is a kitchen tap, basin tap, thermostatic shower and toilet. Tank is actually located at same height as pump.
Unfortunately, it is short cycling very badly (i.e. about once per second). Only the basin tap (which is a domestic type) has enough flow to stop the cycling. The shower and kitchen tap (both caravan types) short cycle badly. The impression at the outlets are that both the pressure and flow are weak, much worse than a caravan with a £10 submersible pump. There is no entrained air (at least after the hot tank is full).
Inlet filter is clear. No hose kinks. Tank is vented. A Fiamma A20 accumulator pre-set to 2 bar makes no difference/makes the cycling actually slightly worse. This is a brand new installation and has never worked properly. There's a few elbows in the system, but I can't imagine they'd restrict flow this amount.
I'm stumped. It feels like a restriction in the pipework after the pump, but there is nothing I can find and 1/2" reinforced hose is pretty hard to block. Could it actually be the pump itself? Any ideas?
