Esther_99
- Dec 11, 2019
- 32
- 58
- Chausson Welcome64
- Since 2014
Morning folks,
We have a Chausson Welcome 64 and have been having a bit of trouble with our water system and I'm looking for some advice / sanity check to make sure I'm not missing anything obvious.
Initially I replaced the cartridge in our bathroom tap, the part that controls the mixing and the flow as the old one was cracked. A simple enough job. Unfortunately, I then heard a leak under the sink so had to dismantle half the bathroom to discover the shower hose had split. Irritating, but again, a simple enough job to replace. Everything looked good. Bad luck both things broke at once, but I had it sorted, I thought.
However, after putting it all back together the water pump, a Shurflo Trail King 7, started to pump intermittently even when everything all taps were closed. Just a few pulses lasting less than a second. This happened every 15 seconds or so, but sometimes wouldn't happen for over a minute i.e. far from perfectly regular.
"Great, another leak" I thought, "must be the shower hose or tap fittings".
To cut a very long story short, I spent several hours slowly isolating different parts of the piping and couldn't find a leak anywhere in the motorhome. No little puddles or even tiny drops on any of the piping or connections that I could see at all. So I did what I should have done at the start and went back to the pump. We'd had a cold night recently (we're in France at the moment). I don't think it dropped below 0, but it might have done for an hour and I hadn't drained the system.
Disconnecting the outflow pipe, I capped the outflow with a stopper, pumped until it stopped and waited.....and got the intermittent pulsing issue. The entire water system hosing was now disconnected so I came to the conclusion the pump is the problem. However, there are no visible leaks here either. No water on the outside. Nothing oozing out of the housing.
The question is, (1) if it is the pump leaking, shouldn't I see water (even a tiny amount) coming out somewhere? Even pumping for half a second every minute should produce something visible.
(2) If it is the pump, is there something I should be looking for. Something I might fix. I know a replacement isn't too pricey but if I can fix this one then I can save £50-60 and get it sorted rightaway.
Sorry for the ramble. Any thoughts much appreciated. At least everything works at the moment, we just have to turn the pump off when we're not using water.
