1881TB
- Dec 29, 2017
- 132
- 51
- Auto-Trail Comanche, 2013
- Spent a few weeks touring Australia and New Zealand about 10 years ago...
I was awoken at about 6am by a humming noise which I first thought was a generator in a nearby van but turned out to be my water pump running for no reason.
It is a Shurflo 4029-181-A32. My van is a 2013 AT Comanche.
I have read previous water pump threads and gone through all the possible causes I could find:
I can't find a significant leak and the fresh tank is full with hot and cold running as normal. It's just that the pump is on all the time. I now have to switch it off at the control panel to stop it.
I have located the screw on the end of the pump which controls the pressure at which the valve should close to stop the pump and adjusted it with an Allen key 3 full turns in both directions to no avail.
I have taken the filter off and emptied the small amount of detritus which was in there.
All the wires seem OK.
Can anyone think of anything else?
