It's meant to but maybe double check dimensions with Colapz.Thanks very much.like the look of the colapz one especially if pump can fit into standard plastic Gerry can
May not be what you are looking for, but my solution was that my sink tap is a shower head that I can pass through the window - simple but effective
We have been using one of these for a number of years. Put in cold water and top up to suit with boiling water - saves firing up the boiler when heating is not being used. When off grid and conserving water we find we can both get an adequate shower with using only about 5lts of water.Left field, but I have a Hozelock pressure shower, kind of like a roses sprayer with a shower head on. I used it extensively over a few years whilst on longer ‘off grid’ fishing trips around Europe. Highly recommended!
Portashower | Hozelock Ltd
A compact, portable shower. Only 46cm high and easy to store. Ideal for camping and caravanning. Key Benefits Include: Ideal for camping and caravanning Easy to control hand spray Integrated lance handle storage 2m hose for great reachwww.hozelock.com
We used the same in our old van, as had not finished the plumbing, before a hot UK summer holiday. Worked really well, wet yourself down, soap up, rinse off. No batteries, very light and uses minimal water. A properly plumbed in system with its own tank and and a hand pump to pressurise the tank would be a good off grid solution. As suggested add some hot water to taste.We have been using one of these for a number of years. Put in cold water and top up to suit with boiling water - saves firing up the boiler when heating is not being used. When off grid and conserving water we find we can both get an adequate shower with using only about 5lts of water.
We recently moved to a bungalow and still haven’t got a bathroom so are using the Hozelock on a daily basis. Fill it with hot water from the bungalow and nip out to the motorhome to shower. The Hozelock shower only cost us £5 (unused) about 13 years ago so doesn’t owe us anything. Have seen that GoOutdoors sell a similar one to the Hozelock, for considerably less.
