Shower Tap leaking (water out from Shower head) (1 Viewer)
May 5, 2014
671
169
Leicestershire
Beginners, got Doggy the van - March 2014
just arrived to Santander last night, water coming out from shower head, seems shower tap not sealing, have to stop water pump.
We have Autotrail Delaware, can somebody advice please?
Here is an holiday period till 7th January.
Feb 9, 2008
8,924
18,663
Corby, Northants
Coach Built
You have already found the short term solution via your pump ! Just make sure any escaping water is directed down a waste drain and carry on regardless.
Sep 22, 2013
200
199
Halifax
Relay self-build
Trainee MH owner
Another possible (and perhaps more convenient?) option would be to unscrew the shower head from the flexible pipe then replace it having put some thin polythene over the end of the pipe to seal it temporarily. If this works, you can at least avoid having to turn the pump on and off.
kelpie
563
420
Glasgow
Bessacarr E745
3 years
Probably won't work ,but , at this time of the year a cork from a bottle of wine pushed in to the shower head pipe.
If nothing else it's an excuse to open ANOTHER bottle of wine:D:D.
John
The Nomad
1,052
1,064
Wandering in Europe
Overcab
Many years
Just keep the pump turned off unless you actually want to draw some water...it's what we have always done; then there's no risk in a pressurised system of a pipe leak/split resulting in the pump discharging all your freshwater tank water inside the MH.
