Shower problem
Ridgewoodwoody
We have an 2019 Elddis Majestic 120. When using the shower yesterday the water was barely dribbling out of the shower head. Both other taps, the bathroom basin and the sink ones were flowing fine. We noticed that when we turned the shower on the usual pump whirring was intermittent rather than constant. Any advice gratefully receive.
Shower hose twisted?
(Not always obvious due to the outer protective cover)
Remove the hose at the mixer tap and see if it flows,then you can narrow down the problem.
Remove the shower hose from the valve/shower tap, then operate the valve/tap and see what happens.
I recon you will get the full flow of water.
Take off shower head. Does tap fully open - hot and cold
Check where the hose is connected to the head there is in some set ups a small valve fitted that you can shut off the flow to the head it’s a small button.
Many thanks for all the replies. Fixed now - suspect a twisted hose, now replaced and all tickety-boo.
