I don’t have one for this MH last one (Hymer) has one but to be honest never used it.
should I have?
Only use I can think of is to stop smells coming up when your grey water tank gets dirty. That is if your motorhome doesn't have water traps on the shower drain line(s).I don’t have one for this MH last one (Hymer) has one but to be honest never used it.
should I have?
Our motorhome does have traps on both the shower drains, but I understand that many others do not.No need for a plug (or plugs). If there is a smell coming from the waste tank, there should be a trap below and it needs re-filling with water after you've stopped travelling. Shower trays don't usually hold much water, you could flood the van if you let the water build up and it could be made of materials that were not expected to get wet.
You've either not taken off the plastic protective cover or you've got a serious limescale problem in your camper!my 2016 Globecar 600L shower tray has 2 plugs - they are slightly tapered - 33mm at base, 35.5mm at topView attachment 368869View attachment 368870View attachment 368871
hahaha! I didn't know it was a protective cover - I assumed it was white on purpose!You've either not taken off the plastic protective cover or you've got a serious limescale problem in your camper!
No, just little itsy-bitsy plugs like the one Gerry has shown.Are they the basket type plugs?
Stops all the crap going down the plug hole when you shower. Collects it all, then easy to empty. Should have been supplied with van.
Yes they are abd then the top clicks on to stop the water had to by a pack of 2 as only one fits bought a second this week as a spareAre they the basket type plugs?
Any good?That's the size I need.
i will try a caravan shop as Google doesn't seem to come up with the right size.
Did either fit 1ten ?
No neither fitted.
Embarrassingly last week I found the plugs supplied with the van!
The van was brand new when we got it and we received some plastic bags with toilet roll holders and the like in them which have been in our garage ever since, I sorted some stuff out and found the plugs!
You're kidding! I haven't got a clue what I was thinking yesterday never mind back in March!!!Did either fit 1ten ?
Minxy Girl that link doesn't seem to work any longer, any chance of another? Not sure of the search criteria you used!
Too big, surelyTry Magnum Motorhomes in Grimsby
