Shower Plug (1 Viewer)
Sep 10, 2017
425
943
Our van didn’t have any plugs in the shower when we bought it from new, they are an unusual size has anyone managed to find any for sale anywhere?
Jul 6, 2018
197
315
North Yorkshire
burstner brevio t640
Since 2010
I don’t have one for this MH last one (Hymer) has one but to be honest never used it.
should I have?
Jul 5, 2013
11,713
13,681
Since 2013
should I have?
Only use I can think of is to stop smells coming up when your grey water tank gets dirty. That is if your motorhome doesn't have water traps on the shower drain line(s).
Edit beaten to it by Paul.
Minxy
32,488
66,008
E Yorks
Carthago Compactline
If you recently bought it tell the dealer to get you some FOC as you should have had some with it. You could just use some bits of silicone mat cut to sit over the holes.
Aug 6, 2013
11,941
16,533
Kendal, Cumbria
Le-Voyageur RX958 Pl
since 1999
I'm trying to imagine a use for such a thing :giggler:.
I sometimes have trouble getting all the water out but up to now it has never tried to get back in.
Apr 6, 2019
3,693
7,299
Eye, Peterborough, UK
RV
FourWinds Windsport 6.8L V10
Google the measurement and buy a couple of cheap ones off fleabay. My house sink is an unusual size 38mm (I think) But found it from dear old Gooooogle
gerry mcg
1,648
2,570
Glasgow, Scotland
Globecar 600L Revn
since 2016
my 2016 Globecar 600L shower tray has 2 plugs - they are slightly tapered - 33mm at base, 35.5mm at top
43,207
48,802
Do you have a plug in your shower at home?
Can't understand why anyone would want to stand in water they just washed in.
If it is to prevent smells from the tank a wet flannel over the hole will do the same job.
two
Aug 4, 2011
4,901
4,560
West Midlands
A-Class Fiat
No need for a plug (or plugs). If there is a smell coming from the waste tank, there should be a trap below and it needs re-filling with water after you've stopped travelling. Shower trays don't usually hold much water, you could flood the van if you let the water build up and it could be made of materials that were not expected to get wet.
Jul 5, 2013
11,713
13,681
Since 2013
Our motorhome does have traps on both the shower drains, but I understand that many others do not.
Minxy
32,488
66,008
E Yorks
Nanniemate
5,929
41,969
Wales
IH
Bought two from Trago Mills last week with hair catcher I had to buy the set of two to get the one that fitted but only cost £1.45
Theonlysue
6,104
7,383
Essex
As Executive 50th an
Not long enough!
Are they the basket type plugs?
Stops all the crap going down the plug hole when you shower. Collects it all, then easy to empty. Should have been supplied with van.
Minxy
32,488
66,008
E Yorks
No, just little itsy-bitsy plugs like the one Gerry has shown.
Nanniemate
5,929
41,969
Wales
IH
Yes they are abd then the top clicks on to stop the water had to by a pack of 2 as only one fits bought a second this week as a spare
425
943
That's the size I need.
i will try a caravan shop as Google doesn't seem to come up with the right size.
425
943
I’ve really splashed out on some on Amazon. Two different sizes hopefully one of them will fit as they are tapered and neither are the exact size. £1.99 each:LOL::LOL::LOL:
Vanman
1,656
3,874
Runcorn
Roadscout R PVC
March 2017
Did either fit 1ten ?
Minxy Girl that link doesn't seem to work any longer, any chance of another? Not sure of the search criteria you used!
425
943
No neither fitted.
Embarrassingly last week I found the plugs supplied with the van!
The van was brand new when we got it and we received some plastic bags with toilet roll holders and the like in them which have been in our garage ever since, I sorted some stuff out and found the plugs!
Minxy
32,488
66,008
E Yorks
10,430
23,268
A Class N+B Arto 69GL
Since 2009
We have used the shower with plug inserted to soak some items before washing which are too big for the sink. Also to soak the tray floor and the shower non-slip mat before washing.
Geoff
