Shower Fitting Confusion (2 Viewers)
Oct 20, 2013
5,299
13,181
South Norfolk
Yes
Our shower head is knackered, so I unscrewed the offending article and measured it. Simples I thought. No it flipping isn't.
Standard 1/2" fittings won't be 1/2" in any dimension if you measure them, and this can cause confusion. Many customers will be sure they don't have standard fittings since they measured their existing shower head or shower arm and they measured around 5/8" or 3/4". But most 1/2" male fittings will actually measure about 0.8" in outside diameter, and 1/2" female fittings will be around 1" outside diameter. (Why is this the case? For the same reason that in lumber a 2x4 isn't actually 2" x 4". Someone decided a long time ago that is how it would be, and that was that.)
andy63
4,672
15,017
south shields
since 1990
hi dawn, take it you are talking bathroom fittings, not mh. you are referring to the standard sizes in british standard pipe thread ie 1/2 inch bsp is .825 '' outside diam and a tapping drill size for 1/2 inch bsp is 3/4 inch..
that's just the standard..
the timber sizes you mention ie 2x4 will come in at that in undressed timber but dressed or planed comes in under 2x4...
all just standards we use in this country (y)
ta andy
DuxDeluxe
14,658
72,771
Planet Zog
A woosh bang van
Do what I did - take the old one with you when looking at buying the new one. Simples (like me)
DuxDeluxe
14,658
72,771
Planet Zog
A woosh bang van
I have it on good authority that it means "I'm ready big boy, come and get it".
Or "I've got a headache, come near me and you're a dead duck".
Drakes are very confused creatures.
Mostly the latter, in my experience - found out to my cost.
11,953
16,570
It's the nominal internal diameter of the pipe (male thread). Doesn't help much when looking at a female thread though :)
Wildman
8,470
Ilfracombe, Devon
Amazon Ambassador
since 1967
BSP British standard pipe is measuring the internal dia of the pipe. Timber (or Lumber in the USA) is measured in inches or mm but only sawn is exact size planed is smaller. (4 x 2 sawn minus whatever the take off to clean it up) Yanks always say 2 x 4 and Brits 4 x 2. It is just because they are awkward.
2,324
10,044
no, it's because it's Cockney rhyming slang ... 4 x 2 = *** ;)
2 x 4 doesn't work
Feb 16, 2013
19,734
52,021
uttoxeter
ambulance conversion
50 years
Just take your old shower head to b and m or poundstrecher or some other pound shop and just check it against the ones there, loads cheaper than eBay
johnp10
7,774
15,181
North Lincolnshire
8 years ish
Dawn,
DIY = Don't........Involve........Yourself.
If you measure a piece of timber, lay it down, don't measure it stood on end.
That will give you the length, not the height.
Complicated, eh?
