Setting off configuration - Water (1 Viewer)
Ashypants
63
43
Chesterfield, Derbyshire
Morning,
Quick question - I’ve seen a few posts, here and elsewhere, about people ready to set off on a trip and they have stated their water load as full fresh water and half grey water/waste. This may be a very stupid newbie question but why do people set off with half grey water?
Thanks,
Ash
Jul 5, 2013
11,723
13,701
Since 2013
Morning,
Thanks,
Ash
I don't know either. Having said that, the only reference I have seen about setting off with the grey tank half full of late is someone who did that on the way to a weighbridge to check their maximum weight.
We use Aires and sometimes wildcamp. As we rarely know where we are going to stop when we set out at the beginning of a day we always take every opportunity to keep our water tank full and dump our grey waste, and our black waste if possible. Can't remember any time that we have filled up our water tank and failed to dump our grey waste though.
Ashypants
Ashypants
63
43
Thanks - this may have been the bit I missed - makes sense when going to weigh.
2,931
9,915
North Essex
Autotrail Delaware
>12 but <13
When you find an aire that needs jetons for fresh water, there is usually a chance to empty waste black and grey. Use some grey to rinse cassette
5,065
5,926
West Yorkshire
PVC
since 2008
We travel with 1/4 fresh water if going on a short trip 2 days max or heading to a site. If wild camping we take as much water as we need for the duration.
If we are wild camping on hard standing we will have grey waste onboard but if parked on grass we water the grass (My Bad)
two
Aug 4, 2011
4,903
4,573
West Midlands
A-Class Fiat
No-one of sound mind would carry waste around with them deliberately. But this is a ‘Fun’ group and the topic of Grey Waste is often used as an opportunity for some to pull a leg or two.
Water is heavy (waste slightly heavier) so I carry as little as possible. That great weight sloshing around cannot enhance fuel consumption or stability, although I can’t say I’ve ever noticed. If I’m going somewhere I know will have water, I take none to very little. If wilding, though, I’ll fill the fresh to the brim.
Waste is waste. You don’t want it, so dispense with it at every opportunity. The last journey of a trip, I will empty the waste, flush it a bit, then fill with the remainder of the hot water and some disinfectant. I empty that when I get home, after it’s had time to clean the waste tank up a bit. Try not to allow solids into the waste: if they collect it’ll start to pong.
1,164
1,348
Malvern Link, Malvern, UK
Chausson Welcome 85
Since 2018
Another silly question from a beginner.
If you are passing a campsite and you only want to dump waste and/or fill up with fresh water , presumably you can just pull in and do so?
Is there a nominal charge ?
We are CCC members , so can we do it free on their sites?
Hellski
989
2,972
Cheltenham
N+B Arto 76 LE
In the UK, I believe CCC members can use facilities but are charged £7.50 for the privilege. No where else will let you just pull in and use services unless you have a booking with them for the night. I'm aware of a couple of UK style aires, Lytham St Annes being one, where they have the facility for dumping black waste and if you have a watering can, could fill up with fresh water.
This is why travelling in Europe is sooooo much easier with many aires having facilities where you can do just as you've asked, some are free and others have a nominal charge.
To summarise, generally when travelling in the UK you need to plan more then when travelling over on the continent.
Riverbankannie
10,525
61,501
Bristol
IH 630 RL PVC
Probably not, CMC notoriously don’t allow it but you might find a private campsite that does for a fee. Do not just pull in and use them.
Freespirit1
731
456
West Wales
Short while after a gap of many years.
Yes - good idea to disinfect it a bit - sometimes I do purposely leave shower grey waste in the tank to swill around and help clean it up a bit as it swoshes about :)
WSandME
368
453
Wigan-ish
Hymer B660 Bestline
SInce 2006
I have been refused at a campsite in France (near Barfleur IIRC) - I asked how much they wanted to charge for me to empty and refill - a flat Charles De Gaulle "Non!" ensued.
two
Aug 4, 2011
4,903
4,573
West Midlands
A-Class Fiat
Yes, you can empty but there is (normally) a charge. The charge covers use of ablutions and taking on water, staying for a couple of hours.
