- May 12, 2019
- 545
- 794
- Autotrail Delaware
- Years Tugging - Newbie MHing
Hi Folks
Wondering if anyone has fitted a Kill Switch to prevent their van from being driven away.
I have a Tracker and the usual Ducato Key and Security etc, but I'd like to have a hidden Kill Switch installed.
It seems the Ducato has two fuel pumps, one of which is mechanical (or so I'm lead to believe), and one electric. My understanding is that if a Kill Switch interrupts the fuel pump circuit the engine will still turn over and start and it may be driven some short distance before there is fuel starvation. And once it has stopped the mechanical pump may allow it to start and drive that distance again. I guess that would cause some degree of problems for thieves but not exactly what I'm looking for.
So I think interrupting either the ignition feed well away from the key and steering wheel (so cant easily be traced and reconnected), or even the starter (relay)feed would be preferable, in which case the engine should not even turn over.
Have any of you Funsters actually done this on a Ducato, and if so would you share the method you used?
Appreciate your feedback.
