Jands
- Oct 12, 2016
- 358
- 565
First diy job on my MH.
Want to fit a second Leisure battery.
The leisure battery fits under the dining bench seat, enough room for a second battery.
The battery is strapped down inside an open plastic box.
The leads look just long enough for that battery.
Need advice on obtaining and fitting.
Need some hold down straps and brackets from where?
The original battery box is open at the top, do I need a covered box?
Second battery needs to be similar design and amp/hour to the original.
Wiring, read advisable connecting MH positive to one battery and negative to the other, if not enough MH wire to do this is it that important?
Don't want to do a rewiring job, just connect the second battery.
Fuses for new battery, read that it should be outside to battery storage. Also as I expect I will just be connecting the second battery in parallel by joining at the terminals is a fuse important, the original fuse will protect both batteries.
Are battery problems commonplace or quite rare?
Any good advice would be useful. As I said know the preferred theory of a fuse for each battery and split electrical cables but easily adjusting original wiring might be difficult.
