I have been meaning to fit a second battery for a while and just never got round to it, today I decided I would have a look at the current battery and the space under the drivers seat in a 2016 Fiat Ducato.
The current battery was 1 year old in January and has always been kept charged, couple of questions regarding the battery. Should I change it and go for 2 new ones or will this one be ok, the ampage is a bit confusing as it says 95 and 85 I'm assuming it's 85 see photo.
I thought I'd take the drivers seat off today to have a good look and make sure another battery would fit, an easy job I thought not so. I have removed all the screw/bolts from the seat base/turn plate, the problem is it seems to be welded which you will see in the photo below. If it is welded I assume you must be able to slide the battery out some how you can't get it out the back or the front that I can see so I assume it's the side.
