Hi,
While playing with the fridge fan installation and replacing the external hookup point, I've found that the metal beneath the vents etc. is often rusty. I've stripped back the flaky paint, treated the rust, repainted etc. and am will be soon be ready to replace the vents. Some came with rubber gasket type seals that - parts of which were embedded into the rust and were damaged when removing the vent and others, such as the new hookup socket have a foam pad to go between it and the metal. I'm not convinced that the foam will keep water out.
What can I put around the edges of the vents to stop water getting down between the joint with the metal body? I would like something that holds a shape but doesn't stick the vent to the metal.
