Screwing advice needed (1 Viewer)
ymfb
798
6,347
Salisbury
AS Kingham
Since 2009
I’m making a door to cover the former microwave cupboard on our AutoSleepers Kingham, I bought a cut door, hinges, handle etc from AS so as to match the rest. The door and cupboard is made from 12 mm thick chipboard. The hinges are so thin as to be difficult to measure the plate thickness with a tape measure, so let’s assume 1mm.
Ideally a Roundhead screw 10mm long and as large as possible diameter would be ideal. All I have found so far are 12 mm long screws. I am wary (sic) of the screw breaking through the “wood”
Can anyone advise the best screws to use and where to buy them.
ymfb
ymfb
798
6,347
Salisbury
AS Kingham
Since 2009
Not sure what they are called.
Nov 23, 2011
476
396
durham
Lowline
since 2006
Try ebay. Put in search for very small screws. Should find some 10mm and under
Oct 7, 2013
5,743
35,952
South Wales
Swift Escape Compact
Since 1988
Is there an existing cupboard door that you remove the screw from and measure it against the ones you have?
DBK
17,910
47,658
Plympton, Devon
PVC, Murvi Morocco
I would use piano hinges with lots of little screws. It will take more work as the side on the door needs to be rebated to get a flush fit but it will never work loose.
ymfb
ymfb
798
6,347
Salisbury
AS Kingham
Since 2009
Piano hinges don’t have the “action” we need, but I understand the principle.
ymfb
ymfb
798
6,347
Salisbury
AS Kingham
Since 2009
EBay Pozzi Drive self tapping screws. Few different sizes below 9.5mm will be ok. Just drill a small hole first dia centre of screw. Try on a piece of scrap first. Tape on drill at required depth. If you try with wood screws the Mdf will just bulge up. You need a pilot hole.
https://www.ebay.co.uk/itm/POZI-PAN...hash=item25ae139e7d:m:m942c-1tSuxWocnGEvs5KMw
I have been pilot drilling the holes for the screws to repair the damage by fitting blocks between the horizontal and vertical boards to avoid damaging the chipboard.
Tomorrow I’m going to Halfords to pick up some self tapping screws.
Thanks for all the input.
DBK
17,910
47,658
Plympton, Devon
PVC, Murvi Morocco
Yes, you need something to keep them open, which is another thing to buy and fix but all our doors use piano hinges and are all solid after 5+ years.
You could consider glueing dowels in place and screwing into those. It depends on the quality of the wood I guess, which you probably won't know until you start drilling into it. :)
Jan 8, 2013
8,395
11,383
Dronfield - Derbyshire
Burstner Lyseo 690G
Happy FLT since 2011
A that short length I would suggest the courser the better. Fine screws will pull out easier.
Jun 30, 2010
7,905
26,794
Cornwall
1992 VW Auto sleeper Mono
Since 2005 this time
Jeezzz mate! you certainly caught my eye with the thread title!
Feel all deflated now! tizent about screwing:doh:
Tiz only about screwing!:crying:wiv a screw driver:laughing::rofl:
Aug 6, 2013
11,834
16,216
Kendal, Cumbria
Le-Voyageur RX958 Pl
since 1999
Once you have a final position and tightened the screws run a pencil around the hinge plate, remove, then use spray glue on the hinge & woodwork. Refit. They'll never loosen but can still be removed.
Sep 26, 2013
4,013
4,770
Market Rasen
Self Build
Since 2003
Cannot understand Autosleeper using doors made from chipboard which is of course quite heavy and not great for holding screws. The doors I used in my conversion were surplus Autotrail curved doors and are lightweight but more importantly have solid timber where the hinges fit.
Silver-Fox
9,033
26,653
Cheltenham Spa
Rapido
im a not so newbie
Sorry for the late pick up been a tad busy.
You can pick up Reisser screws probably 3.5 or 4's in size.
Measure the cabinet thickness that will give you the length of screw required.
My guess is it will be 12mm I'm sure they do that length.
These are quality screws with a good "bite" on them.
HTH
R
Robert Clark
I’d suggest using 4mm Euroscews
Great fixing strength
