There is a 50A fuse on the leisure battery, and also a 50A and 20A fuse near the starter battery. It's the 50A starter battery fuse that I think needs to be removed.If I remove the 50A fuse for leisure battery charging that would mean there would be no charge to the leisure batteries whatsoever, even on EHU?
If the B2B output voltage is above the engine battery voltage it will flow the wrong way through the EBL causing a loop. This is why you should do as autorouter says and remove the 50A fuse. Defeats the purpose of having a B2B if you do not disable the original split charge circuit.paddymcc The B2B does not operate through the EBL, it is completely separate. My concern is that the EBL will also be charging the leisure batteries at the same time when the engine is running.
That route through the EBL is good for about 15A, ie about 200 or even 250W of solar panel. Anything more needs to go direct to the batteries. One of the pins of the 3-way solar connector goes to the starter battery, and is usually only a trickle-charge, so that will be OK to route through the EBL even if the main leisure battery charge has to go directThe solar controller is also routed through the ebl, would I be better connecting them directly to the batteries?
