Sat nav turning self off (1 Viewer)
Aug 19, 2015
639
11,769
West Sussex
Since 2015
Recently there was a post about someone’s sat nav just turning itself off. I have searched but can’t find the thread. Ours is doing the same today, quite a few times. The cable is pushed right into the holder.
Can anyone remember the thread please or anyone else had this problem?
Actually it’s rebooting not turning right off
43,329
49,441
Sounds faulty to me.
Even with the cable disconnected it should switch to internal battery.
Try pushing the reset button.
Location will be in your manual.
Oct 24, 2015
5,287
33,405
Helgas house
hymer e650 battered!!
None
Hi cruisers, I think it may have been me!
I was advised to tape the fitting that goes into the lighter socket,, and push a pin into the hole on it to reset it! I have done both, and reset to factory settings on screen,,, we shall see! Good luck!
Aug 26, 2008
4,762
24,946
B&NES
Van Conversion
since 2007
Had a similar irritating reboot problem with a smaller Garmin used in the car.
The cable connection to the socket on the back is a bit loose.
Oct 11, 2016
1,316
2,197
Bognor Regis
Bailey Adamo 69-4
6 years
Are you using a genuine charging cable? I only ask as a few years ago my son lost his and used a cable that was not garmin and experienced similar problems. Genuine cable sorted the problem.
Emmit
8,034
17,751
Cornwall
Pilote Explorateur
Jan.2014
And if you can't find the 'Reset' button and it's a Garmin, you will find that if you remove the product identity strip on the back of the unit, you will find a 'Nipple?' and by using a fingernail pressed on it will set the unit.
The Cruisers
Aug 19, 2015
639
11,769
West Sussex
Since 2015
Ours is a tom tom and it’s a genuine cable that came with the device. No problems until now. We are driving at moment will check for reboot button later. Thanks.
