Any views, recommendations and opinions on best rust treatments/killers on the market please…
???? I read it as OP looking for product to treat already present rust and not a treatment to prevent future rust.Cheap cans of spray grease.
If you can get to the whole of the metal, front, back, sides, edges etc this is perfect. Unfortunately I suspect the OP is on about a vehicle. getting inside of chassis rails, sills etc is not possible. Cutting out is the only answer in those cases, otherwise the rust just comes back from behind..I use phosphoric acid to convert rust back to iron / steel and then treat with protective layers of paint and grease. It works well and is easy to apply, as long as you can get the liquid to the rusty areas and is far easier than abrading the rust away with wire brushes etc.
Agreed. I made some holes in my sills this summer to treat the rust coming through and add preventative paint and grease. Not ideal but it might be a longer term solution to doing surface treatment every year or so.If you can get to the whole of the metal, front, back, sides, edges etc this is perfect. Unfortunately I suspect the OP is on about a vehicle. getting inside of chassis rails, sills etc is not possible. Cutting out is the only answer in those cases, otherwise the rust just comes back from behind..
As with anything like this the answer is "It depends"...
You’re right Gromett … I’ve got a few little bits to do on the mini I’ve just bought, a few little bubbles the size of 20p piece on paintwork but I want to clean off the underneath and treat with rust killer then seal with waxoyl or similar…If you can get to the whole of the metal, front, back, sides, edges etc this is perfect. Unfortunately I suspect the OP is on about a vehicle. getting inside of chassis rails, sills etc is not possible. Cutting out is the only answer in those cases, otherwise the rust just comes back from behind..
Another vote for Fertan. It even smells nice!I read a few reviews before buying some recently. Fertan Rust Converter seems very good but is expensive. As I had only a small minor bit of rust to treat I bought some Hammerite Kurust which is almost as good as Fertran but a lot cheaper.
Another one here.Another vote for Fertan. It even smells nice!
