Roof cleaner Issue
WEST SUSSEX
HYMER B SL 674
SINCE 2005
Last spring decided to give the motorhome a spin clean inside and out and for the roof bought a proprietary product specifically for the roof as advertised.
Read the cleaner had no acidic ingredients, diluted the cleaner as instructions and rinsed afterwards.
Since then a clean roof but very noticeable streaking on the motorhome sides, decals, rear and windscreen.
Suppliers suggested wash with a Pu neutral shampoo which I have done many times - end result very slightly better but still very visible. Reluctant to buffer which is their suggestied fall back if the shampoo doesn't work - we have a ceramic coating so do not want to compromise this, or the decals!
Any others had the same issue and have you managed to overcome it? Thank you.
You should always use a Ph neutral wax free shampoo. I had a work pal who used a different shampoo to that advised and absolutely ruined his new car only weeks after having the coating completed.
The last thing you should ever do is to polish an already ceramic coated vehicle, You will just remove the coating due to it being very very thin.
You could try Autoglym Foaming Car Wash or Bodywork Shampoo Conditioner, Ph neutral and very soft on bodywork but very good.
All the best.
Many products, especially traffic film removers, advise starting at the bottom and working up. This is to avoid exactly what you have experienced.
Geoff
Rain-x glass cleaner removed the streaks from the windscreen that the roof cleaner left on it that plain water wouldn't remove, I haven’t tried it on paint work though, it might be worth a try.
You havnt said what you used, I have noticed there seems to be quite a lot of unhappy people around who have used that Jennychem stuff.
It's very effective but it can leave streaks, i would use it more diluted then recommend and do small areas at a time well rinsed off and on cool day with little wind, whatever you do don't let it dry.
Maybe, but to be on the safer side, especially with all the bad reports about it, aren’t you better using the dedicated other stuff to wash an expensive motorhome.
Auto glym, Star Brite, Meguiars etc etc
I think it depends on how dirty the roof is, I'd like to see how any of the products you mentioned would perform on a really bad roof, I'm sure they'd be fine if used regularly and safer as you said. But this was what my roof was like having not been washed for a few years and how effective Jennychem was. It's water beading on the roof not blisters :giggle:
Yes it was that product!
All the best.
Thank you Autoglym is what I used! Will see what the ceramic people have to say.
Yes I suspected it was, to me that’s the sort of stuff you would use on a knackered old hgv truck I’ve heard of quite a few people that’s had the finish ruined on their motorhome.
I think Al n Val was one of them.
It certainly was
It ruined my finish in the Moho that badly I had to have it machine polished and it even burnt into the windscreen which also took a lot of machining together the streaks out
I wouldn’t use Jennychem products if it was free
I was using Jenny Chem on my last van not used it on current van. I ceramic coated it and only use a pH neutral snow foam now.
Totaly agree the dried white residue is an absolute pain to shift. What has it done (if anything to my solar panels)?
I now use it a lot more diluted than reccommended.
Jennychem is brilliant stuff if you use it right .... I learnt a very hard lesson a few years ago when using "Elbowgrease" spray cleaner on the sides of the van.. got the stuff on a couple of my Dometic Seitz windows and basically ruined them (crazed and cracked)... the stuff attacks polycarbonate plastics and to be fair it does warn this in the very small print on the back... over £400 each to replace the glazing panels. yet I still see loads of folk recommending this cleaner.... As for Jennychem yes it will damage your decals if left in contact for a prolonged period...and that period is very short... so what I do is have a fresh water hose on standby and only wash a small area with the cleaner then rinse off immediately... do not let it sit in contact with anything for too long... using it this way I've not had any issues and I have matt decals on my van so have to be extra careful.
But there’s an issue as there is non of that information on the product - something that my legal people will be picking up with them shortly. Particularly as seen on site there are many that have experienced the same problems which they are clearly aware of.
Totally agree
They fail to tell you anything about the issues it caused to our motorhome and that’s with mixing it perfectly to they’re instructions
They failed to respond to my emails asking for help and advice so I’ll continue to slate them as long as I feel the need to
Totally agree
I will let you know how I get on in following this up. Will send a pm if I get anything positive.
Jennychem is ace stuff, as long as you use it bit by bit and wash everything off really well before it dries.
As an ex boat owner I can confirm Star-brite products are superb.... their Premium Cleaner Wax with PTFE is an excellent polish .. I use it to keep my van nice and shiny.... Its designed to keep a nice shiny finish on yacht hulls that spend all their lives in the harsh salt water marine environment so if you think of your van as a boat on wheels it works ace. ;)
Better stock up then , they won't be able to sell it much longer when the expected EU PFAS ban comes in .
I'd advise never bother washing the roof 👍🏻
