Roof air con (1 Viewer)
Middy42
248
69
Fleetwood
Since the 70s
Hi all, has anyone got the dometic roof air con with the Heki. First are you happy with it and second does the Heki open. Barrie
Soozywoozy
534
452
Oxfordshire - edge of the cotswolds
Hymer B 704SL
2014, 2 motorhomes
Heki doesn't open and yes very happy with it, fast efficient, heats as well. Not used much due to non summer, but has been great for cooling down m/ h fast when been out all day.
MikeD
3,936
3,697
London
IH PVC
We have a freshlight - Not deeply impressed with its performance.
We had the Dometic engineer out to it as it does not really push out cold air.
He reckoned its about as good as they get.
I would not buy another.
Middy42
Middy42
248
69
Fleetwood
Since the 70s
Thanks for the replies, but one out of two not good, so will go with Truma Comfort. Barrie
Inthezone
146
105
Berkshire
Have had the Fresh Jet fitted although no roof light it has a led light built in, it works well when we were in cornwall in july when it was 27 degrees outside it was a constant 21 inside speak to eddie at vanbitz as they recommended it and fitted it also if you decied to change vans you can take it with you and refit the original rooflight.
Soozywoozy
534
452
Hymer B 704SL
2014, 2 motorhomes
i would also think about weight as adds to payload and electric amps
The freshet, is about 42kg, but only takes 2-4 amps - quite important if you don't want to blow the electric and on continental sites with lower ehu supply
we have kept the old heki to replace if we sell the van and take the a/c onto the next
Sep 24, 2013
145
182
Torbay, Devon
Since 1992
I have got the Truma aventa fitted , we'll pleased with it, have not tried the heat mode yet but certainly cools down the M/H.
Don
Middy42
Middy42
248
69
Fleetwood
Since the 70s
Have decided on a Truma Comfort, might get a deal at Lincoln. Barrie
