Rm4505 dometic Electrolux fridge freezer not working (1 Viewer)
Bradybunch
Bessacar
August 2018
Hello our motorhome fridge packed up on us a couple of weeks back. The PCB has no blown fuses but there doesn't seem to be any electric going to it. So I'm thinking main fuse box which I am having checked our by an electrician on thursday.
The fridge is 19 years old and the parts obsolete so I am looking at a plan B. How easy is it to change a fridge?
TerryL
6,171
8,174
North East
Low Profile
It's not that difficult, bearing in mind you'll be maneuvering a heavyish object in a confined space. Remember you'll need to disconnect the gas and 240/12v connections first, but they're usually quite accessible, probably behind the lower fridge external vent. For one reason or another I've taken mine out a few times, holding screws usually behind plastic screw covers just inside the fridge door.
Your problem is going to be finding another but if you Google your fridge name and model number, plus "replacement" you'll come up with a few ideas. But the same Google search I did came up with quite a few parts too so you might try those first.
Oh yes, and :welcome4:
Sep 3, 2012
7,528
25,998
Cheshire
C Class Elddis 175
8+ years
Make sure it will fit thru the hab door, heard of some going thru windows, after dismantelling same and some had to be taken through the cab doors.
Bradybunch
Bradybunch
Bessacar
August 2018
I'm hoping it's a blown fuse. I did take it to a repair place but I don't think they even looked at it. I know that a new replacement is about 2k which is a daft amount of money. Just took the vents of and there seems to be electric going to fridge which means it might be the pcb! ??
Dec 12, 2010
5,404
21,513
Cumbria
That resistor just below the top left glass fuse looks as if it's overheated a bit ? Might be worth having someone check it out ?
Campervan_man
997
1,720
Dethleffs Globebus
Just remember LPG is very dangerous, Yes you can save money DIY but you can also DIE as well.
Apr 27, 2016
6,857
7,963
Manchester
A class Hymer
Since the 80s
The fridge works by heat applied to the cooling circuit, which circulates the refrigerant gas/liquid mixture and magically produces cooling. The heat can be a 12V element, a 240V element or a small gas flame. The control board switches between the heat sources, either manually or automatically.
First thing to find out is, does the cooling circuit still work? I'm assuming that turning the control knob to 240V doesn't have any effect.
The 240V element is located down near the gas flame. The 12V element is next to it. You could disconnect the wires to the 240V element, and if you can use a meter on the 'ohms' setting, check the element's resistance value. It should be about 200 to 300 ohms.
If it's OK, you could connect the element directly to a wire with a 240V plug on it. Plug it in and wait for a few hours to see if the fridge starts cooling. Of course don't leave it like that for a long time, because you're bypassing the thermostat. Then at least you will know that the cooling circuit is working and it's worth buying a new control board if that's the problem.
Qiki
9
hymer b754
Iā€™m having the same problem ( 220 v working sporadically and switching to gas also all the time . The resistor you see that looks a bit overheated , my pcb and this resistor looks exactly the same . Is it possible to get the resin out and solder another resistor? Iā€™m not sure the pcb can be replaced for such an older model. Iā€™m concidering halving the heat element 220v renewed ( the reading Iā€™d about 250 ohm, but gets a bit higher or lower when heated. Is it worn out, instable ? Iā€™m also concidering a self built in thermostat and connect the heat element myself to 220 vā€¦.
Jan 19, 2014
9,368
24,704
Derbyshire
Elddis Accordo 105
since 2014
The resistor has probably just been getting warm, some do when operated near their wattage rating, they get a lot blacker than that before failing.
The heater sounds OK too, when they fail they go open circuit.
You could fit one of these controllers on the mains element, they are Chinese but good quality, I've used a few.
Elitech Digital Temperature Controller Thermostat AC110V-220V External Temperature Sensor -50 ā„ƒ ~ 99 ā„ƒ, STC-1000X Amazon product ASIN B087NF5LVX
Jan 19, 2014
9,368
24,704
Derbyshire
Elddis Accordo 105
since 2014
w2f
You could even set the above controller up to auto defrost (ie fix the sensor on the evap and set cut in to +3.5Ā°c šŸ‘Œ)
Apr 27, 2016
6,857
7,963
Manchester
A class Hymer
Since the 80s
The first thing I'd check is the incoming mains voltage to the fridge. Those symptoms are exactly what you see on a campsite where the mains voltage sags below what the control board thinks is OK. You mention 220V, so it looks like the voltage is starting out at the low end of the mains voltage specification anyway. Some people on here have fitted a mains voltage stabiliser to solve the problem, so that's a possibility if that's what the problem is.
The element resistance value does vary as its temperature varies, this is normal.
Mar 12, 2012
1,395
1,612
Bridgend, South Wales
Just started!
This is a very interesting thread for me as I have similar issues with an Electrolux RM4505 AES.
Was there a resolution to the problem?
Mar 12, 2012
1,395
1,612
Just started!
Update:
It wasn't the switch! It was the track from the switch that had a very small break in it, I tried to bridge the gap but as the board had lacquer on it, it wasn't possible. So I had to bridge the break using a Dremel to remove the lacquer a little further on.
