CamperJack
I am looking at ring connectors for the electrical wiring.
For example I will need a ring connectors to attach to the 30A battery to battery charger, via a midi fuse, to the batteries.
For this I will need two M5 connectors to attach the wire to the fuse. And a mate or M6 to attach to the battery terminal studs.
The problem is the fuse is rated at 30A to protect the 30A B2B. But I can only find 15A connectors, like the ones below from Halfords. Surely a 15A connector will melt before the fuse.
Are there higher amp rated connectors out there, or am I missing the point entirely?
Also, nowhere does it mention what size wire these connectors take. And my wire size will vary - I'll be using 3, 6, 10 and 35mm cables.
I didn't think simply buying the connectors would be this complicated!
Halfords Ring Connectors (HEF142) 15 Amp/5mm | Halfords UK
Shop the latest Halfords Ring Connectors (HEF142) contains 3 x 15 amp, insulated ring connectors with a 5mm diameter at Halfords UK
www.halfords.com
