Bubblyboy
Hi all,
I'm just looking for some advice re the Rewire Security Trackers if anyone has fitted them and their experiences of them....
I have done quite a bit of research and these Trackers do come quite highly recommended... I just have a couple of questions that some of you out there might be able to answer hopefully...
I was pretty well set on buying the DB2 but on the ebay listing for that model, in the description it said....
"Please note; if your vehicle is fitted with a trickle charger or a solar charging system, we recommend our more advanced model DB1-Lite"
Well as we all probably do have at least a charger I was wondering if anyone knows why they specifically mention that the DB1-Lite is best in that situation?, I can't find any info on the Rewire website that refers to this...
My 2nd query is regarding the connection to the battery, does it have to be the vehicle battery of can it be the leisure battery? I have a solar panel so I just thought that if I run it from the leisure battery then it will be continually charged up off the solar, rather than draining the vehicle battery? Again I can't really find any info on this at all anywhere.. I did wonder if it needs to be on the vehicle battery to monitor its voltage for changes, perhaps indicating that the engine was starting, so it can alert the owner but I could be wrong there...
I could be getting too technical about all this and that either of the trackers will be fine but thought that I would just ask you knowledgeable peeps out there first!
