Replacing tubes with LEDs (1 Viewer)
Jan 26, 2017
3,467
11,716
Mid Suffolk.
Autosleeper Inca
Eight Years and 28,000 Miles.
I want to replace the 8w tubes in my light fitting s with LEDs.
Looking for recommendations and any advice please.. Picture shows existing twin tube fitting.
I have six of the fittings in my Inca..
MickandDi
11
6
Kent
Don't own one yet
There are plenty of how to vids on you tube, but I'm sure others will answer with more details.
LesW
Jan 26, 2017
3,467
11,716
Mid Suffolk.
Autosleeper Inca
It's not so much the 'how to', more about where to get quality items, that are a direct replacement.
davejen
1,861
1,235
Preston
Given up travelling
Since 1992
I replaced the fluo tube in my awning light with a COBB led strip off ebay, just removed the electronic bits to leave + &_ leads . stuck with double sided tape. Worked well for a couple of quid.
Cheers Dave(y)
Ridgeway
3,650
6,134
Lausanne
NiBi Arto 85E
Since 2012
There's a few T8 and T5 LED based tubes i.e. a tube that fits into your fitting just as the regular one but inside are LED's.
Sizes will be the limitation though and prices are not that cheap.
LesW
Jan 26, 2017
3,467
11,716
Mid Suffolk.
Autosleeper Inca
Thanks all, I've ordered a pair of the 'Cobb' ones to start with, only £1.99 so nothing lost.... and thanks Roger for your link that's very helpful.
Mar 23, 2012
9,519
31,873
sleights
c class
also must be inneficient turning 12v into high enough voltage for a fluorescent strip and back to 12 v again
May 7, 2016
7,226
11,686
West Sussex
Carthago Compactline
Since 2003
Some led bulbs are voltage sensitive, designed to work on 12v not the 14+v needed for charging batteries. When I converted my previous mh to led I had to add small electric circuit boards into the fittings to stabilise the voltage at 12v. Cheap off ebay but a bit fiddly to fit. I think the 12v g4 led bulbs I used were originally designed for kitchens and bathrooms where the 12v comes from a stable mains powered supply and charging voltages are not encountered. The led spot lamp fittings in my new mh have small circuit boards built in and it is possible that these are there to protect the leds from the higher voltages needed in battery powered circuits.
magicsurfbus
4,673
10,127
NW England
Bessacarr Coachbuilt
Since 1997
Last time I did that I removed all the tube light fittings completely and replaced them with new LED-based light fittings. When it came to replacing halogen bulbs with LED bulbs in the smaller lights it was sometimes necessary to rotate the bulb mount by 90 degrees. A bit of Araldite saw to that.
