Replacement rear view camera
oldaljones
northampton
Bessacarr E560
Since 2014
Hello everone, I need to replace my rear view camera, it's fitted to my Bessacarr E560 2011 vintage. The camera is marked REAR VIEW CAMERA MODEL RV77-AH MADE IN CHINA there is no makers name, it was fitted by Bessacarr from new, can anyone help me find a replacement, thanks in anticipation
oldal
It is "Raise the dead thread" time :)
Having had the same problem as the OP, I am in the process of resolving the issue.....
I have removed all of the old camera from the RV77 casing and am fitting a modern camera into the same housing. One of the problems is that modern cameras either use a 4 pin connector or, more commonly, a phono (RCA) connector for the video and an in-line DC connector for the power. This is easily resolved by means of a simple adapter cable, to convert the original 6 Pin MiniDin Motorhome cable and Reversing Trigger line to the Phono and DC connector required (pics to follow).
This would be ideally suited as a replacement...
