Doobray
Some useful stuff amongst that lot
It only matters if you regard 7W as excessive consumption - heat dissipation, fuse, & wire size, will be fine. However I offered that particular one as the first of many that came up on the search just so you would know that they're readily available.Had a look only issue they are 7W which is too high max is 2W thanks
