Replacement Clean Water Locking Tank Cap
PPVC Autocruise Alto
I'm a newbie
Hi all just asking if anyone has any idea where I can obtain a locking clean water filling point tank cap, Mine was never correct on our 2nd hand van and two out off the three plastic locating lugs are now broken ( duck tap is holding the flap cover located ok )
The van is a 2015 Alto Autocruise PPVC currently in Switzerland but home soon.
Thank you I will have a measure up and check it out
That's what I replaced ours with when the original gave up locking.
The major downside is, of course, it's not the same key and after putting the original key in and cursing and swearing that it's broken again you have to surreptitiously remove the wrong key and insert the right one whilst crying out, "got it now"!:doh:
Thank you Bobby-gg unit arrived today and fits correctly.
If the new one comes with the zadi style barrel and your current broken one is zadi style as well then barrels can be swapped so the new cap has the old barrel in it 👍
But be aware there are two different diameters as I found out after borrowing a removal key from another Funster.:doh:
