Replacement Brake Pads (1 Viewer)
Feb 22, 2011
9,098
17,714
Newcastle under Lyme
Hymer B544 A Class
Since 2015
I'm planning to fit new brake pads over the winter.
Does anyone know if Hymer fitted uprated or larger brakes or will they be standard Fiat ?
Looking on euro car parts website the description gives a payload for the front pads at 1800kg which seems odd.
Any tips for ordering the correct ones gratefully received (y)
2003 x244 2.8 JTD
TIA
Silver-Fox
9,033
26,682
Cheltenham Spa
Rapido
im a not so newbie
Standard Fiat, I don't like Eurocarparts site, but yeah try a local car parts supplier.
Euro are ok for some items.
Part of the same group is carparts4less and cheaper than Euro 😊
I find GSF helpful to confirm what you need and then order online.
Oct 29, 2016
4,362
47,741
Surrey
Carthago C Tourer
When I did a search recently I discovered that there were about half a dozen makes of Callipers & Pads available.
For my van year 2017/18 2.3Ltr 150PS it seems there are two types of calliper/pad on offer, "The Light Chassis" variant which has a single piston calliper, & "The Heavy Chassis" which has a dual piston Calliper.
Both have the same size brake disk of 300mm, so an upgrade for me when needed is to fit the Dual Piston "Heavy Chassis" Calliper/pad set, which IMHO it should have anyway running at 3850G's.
There are also Brenbo uprated disks, but I think the dual pot callipers with pads to match would be sufficient.
Hope That helps.
LES
Nov 4, 2011
5,676
38,803
Uk
I bought Mintex disc’s and pads off eBay and had a problem with pads squealing, contacted Mintex and they sent stick-on anti squeal shims for free, which sorted it.
Best measure you discs to be sure.
Jan 27, 2018
2,481
1,942
Northampton
Rapido & Bongone
I got my brake parts from these.
they list a lot more detail than most when listing the items, such as calliper manufacture, wheel size, disc size. They also do a good range including some quality manufactures
Liked the detail, when i got to "correct" model.Typing in reg no is pointless for at least 2 years i got "number doesn't exist" now i mostly get not known or occasionaly Fiat Rapido and no info. this site thinks Ive got a Tipo. I'm not the only one?
Feb 25, 2020
248
488
PPVC Autocruise Alto
I'm a newbie
Just replaced the front pads on my Ducati heavy duty chassis so 16ā€ wheels and twin pot Brembo calipers genuine Brembo pad set from Euro Car Parts Ā£66
Sep 29, 2007
604
667
Wantage, UK
Motorhoming since 2006, 30 years tent camping in Africa
I use AutoDoc for most general spares.
Where possible I use CoastalMororhomes - sometimes phone to make sure it’s the correct part. Great service.
I use EuroCarParts less and less - too many wrong parts.
Oct 29, 2016
4,362
47,741
Surrey
Carthago C Tourer
Might be a silly question, please bear with me.
The brakes on my van have never been that good, even from brand new, never inspired me with any confidence. I have had it on the MOT rolling road 2 or 3 times since new, and it passed its brake test under load conditions...on paper.:unsure:
The van is on 16" Alloy wheels, so I presume has 300mm disks (which I will check next spring)
I am also assuming that as it has the light chassis, that it probably has single pot brake callipers, despite the vans max weight at 3850KG's (again I will check this also in the spring)
My thinking is, I will if single pot are discovered, upgrade to dual pot callipers, and appropriate sized brake pads, even fit uprated scored disks if that is necessary.
My question is: will I need to change the Calliper Cradles, are they different for bolt spacing for single or dual pot callipers?
The reason I ask is that I haven't seen different sized Calliper Cradles mentioned for single/dual pot callipers as yet, so maybe the bolt spacings are the same? Thought I would check with you knowledgeable guys 1st.(y)
Many thanks.
LES
Two on Tour
9,731
45,447
Elddis Autoquest 175
Since 2010
Many thanks.
LES
The standard callipers are 2 pot as far as I'm aware.
Oct 29, 2016
4,362
47,741
Surrey
Carthago C Tourer
I am hoping that is the case Paul, if so then I need to look at better brake pads than the OE fitted, or indeed maybe better disks.
I wont know for definite until I get a wheel off the front, so will be none the wiser until next spring.
Its confusing as suppliers list light chassis as having single pot callipers, and heavy as having dual pot, some even mention dual pot callipers for 3500KG vans and other dual pots for 4000KG's.:unsure:
Thanks anyhow. (y)
LES
Mr B
985
2,551
Yorkshire
Rapido 7065ff Design Edit
Since 2015.......
Les. Check your pcd on your wheels..
118 pcd are used on a light chassis…
130 pcd are used on a heavy chassis.
PCD….. pitch circle diameter of the wheel bolts..
Sep 18, 2015
690
687
Selby, North Yorkshire
Rapido 8066DF
I have an A class on a light chassis with 280 mm dia discs and 2 pot calipers and are poor brakes in the mountains etc not up to the job in my opnion, i read somewhere 280 mm discs are for up to 3500 kg and 15 inch wheels i run at 3700 plus and Rapido have clapped 16 inch wheels on so i dont expect any improvement it is what it is.
Feb 14, 2021
2,918
6,012
Milton Keynes, UK
Burstner Lyseo 727G
19 month year 18000 miles UK, Ireland, France, Spain, Germany, Italy. Campsites and off Grid.
Thanks anyhow. (y)
LES
Having messed around with pads calipers and discs for years on my track car the concenus of opinion seems to be that....
1. Discs make no difference to the quality of braking. Buy the cheapest solid discs available.
2. Bigger calipers, 2 pots etc really only improved brake fade/boiling fluid with long hard use as they dissapate the heatbetter. Theo not improve barke performance. When it comes down to it you still only have the same bit of rubber contacting the road.
3. Brake pads are where it's at. These can vary in bite, feel, dust and longevity. Start with pads before touching anything else. It will probably be all you need to do.
Portland
923
1,424
Conwy
C class
20 years
Cargo, Festival trade park. Just down the road from you, think about replacing disc's.
Figaro
Feb 22, 2011
9,098
17,714
Hymer B544 A Class
Since 2015
Looking at brake Brembo pads, there seems to be options.
Anyone know what the difference is and which will be correct ones for my B544 at 3900 kg.
TIA
Lenny HB
50,153
138,161
On the coast in West Sussex
Hymer B678 DL
They must be for the light chassis my Hymer front axle is 2300 kg.
I've had a couple of light chassis vans the brakes on the heavy chassis are a lot better.
