Renault Master Minibus floor.
Eyelobes
Renault Master
Hiya! Im converting a 2005 Renault Master Minibus to a full camper van. I have removed the wheelchair lift and lifted the floor but find a huge steel framework underneath that the chairs were bolted to. It weighs a ton!! It was bolted to the chassis. As Im not carrying any passengers in the back I dont need seats fixed to anything. Does anyone know if I can legally remove this framework? I would like to so that I can lower the over all weight. I hope someone out there can help before I start cutting it up to get it out! Thanks! :nod:
When I had to fit seatbelts to one of my Double Deckers to comply with requirements of one of my new school contracts, I had to have similar fitted by a specialist company in Lincoln because each seat had to pass a 'Strain Test'.
I agree with pappajohn, if you leave it, it has to comply with MOT regulations, if you remove it, IMO, no problems except the new weight might need a re-register?
Hiya..thanks so much for the replies Pappajohn and L'Hobo! The reason I became a little concerned was whilst under the minibus I noticed that the sills were different to most other vans I have had the occasion to lay under. I started to think that maybe the frame was actually a stressed part of the chassis. I did notice that in the supplementary handbook for the minibus it showed the frame as a spare part. The whole chassis is in excellent condition with not a spot of rust anywhere, and the floor of the van looks like a normal van with cargo tie points at the 4 corners. The floor is a single skin..as are the sills. I will have to cut the frame into 5 pieces to get it out so I am a little hesitant! Any more thoughts gratefully received!
Oh..and its plated at 3.5 ton.
Sorry..Sills are not single skin! I was tired after being under the van all afternoon. Not getting any younger!
