I am taking a solar panel off the roof which is stuck with mastic any ideas how to remove it safely without causing damage.
I was wondering that too as i need to remove my skylight heiki to renew the mastic
Will be using W4 as i had seen others mention it for the job , thank you for the infoyour roof window will (hopefully) be sealed using a non setting mastic , not a PU adhesive or Sika ..
clean off as much as you can with a plastic scraper, then use white spirits on a rag to clean off the rest.
To re-seal use a non setting mastic such as Carafax IDL 99, or Hodgsons seam sealer , or W4 mastic on a roll .. find it on eBay.. it's easier to apply, no mess and you get a nice even layer
Sika and other PU adhesives should never be used for sealing windows.. yet people still insist on using it..
