Removing instrument cluster from 2014 Peugeot boxer
Jul 15, 2009
106
77
Bridgend south wales
PVC
i have taken the 2 screws out from either side of the cluster ,it moves forward a little bit but can’t get the cowl over the cluster to come off,anybody any ideas how to remove it?
dave newell
3,271
4,360
Telford, Shropshire
Home converted PVC
26yrs
Pull up at the rear of the cover panel then slide towards you. Two t25 torx screws then hold the cluster in place. If you disconnect the cluster DO NOT turn the ignition on while it is disconnected.
D.
paulj
Jul 15, 2009
106
77
PVC
Dave thanks for the info got it out ok this morning,is there anything I should be aware of when I reinstall it as you mentioned not to turn on the ignition when the cluster was out
Thanks in advance
