keith
- Aug 25, 2007
- 3,421
- 1,864
- Autocruise Starseeker
- Caravaning since 1974 - Motorhoming since 2003
Well it's not actually a dish it's a Camos flat sat dish receiver. which I discovered today has let water in.
As far as I have been able to establish it's not the bottom plate that is at fault because the roof lining is not wet but the water is coming down the spindle that turns the dish.
These systems are no longer available and I have not been able to find any information on the internet as to how to dismantle the block on the roof. I looks as though I will have to remove it to get at the spindle and see if there is a seal gone that lets the water in.
So what is the simplest way to separate the dish plate from the roof as it has a LOT of Sikaflex holding it down and has been there for 10 years? Is there a spacial way to remove Sikaflex so that I will be able to re fix it if repair is possible?
Even if I cannot repair it I will have to remove all the Sikaflex when a replacement is fitted.
Any help will be appreciated.
