Removal of main waste water pipe (1 Viewer)
RobGriff
244
212
TONYPANDY Rhondda Wales
Autotrail Tracker LB
Hi has anyone removed the main outlet pipe from the waste tank , seems that I have blockage somewhere, could be in the pipe or the tank thanks
RobGriff
RobGriff
244
212
Will try a small bore plunger to see if that will shift it. Thanks Stealaway will have a go tomorrow
Apr 6, 2019
3,735
7,442
Eye, Peterborough, UK
RV
FourWinds Windsport 6.8L V10
Advice will depend on what type of tank and fitting? Picture will help us to help you.
On Mine I can reach inside the large bung at the bottom and unscrew the securing nut inside if i needed to.
Mar 12, 2021
450
642
Renfrew Scotland
kontiki sport
20 years tugging .5 years MOH.
Your going to use a plunger šŸŖ  is it your sink thatā€™s chocked.
If not as said above blow up outlet pipe from outside.šŸ˜€
Apr 22, 2018
6,815
12,551
Herts.
Adria Coral lowline
Shove a hose up the outlet. Safer than blowing up it. Iā€™ve found in mine, and others the blank that was cut/drilled out and has been left inside the tank.
Feb 21, 2016
4,916
29,400
Uk
Since 2017
All of the above...plus you can buy drain unblocker at a camping shop.
May 30, 2019
711
1,031
Aberdeen, UK
Adria Twin Supreme
Since 2018
Careful with a plunger, you could easily burst a push fit waste fitting somewhere between the sink and tank. Better to use hose from bottom, gently at first, or an air line if you have one.
