Does anyone know if there is such a thing available?
Thanks in advance.
Richard
Thanks in advance.
Richard
As a matter of interest maybe to others ,, Against the better advice of Autogas, I requested the same led system to be fitted to twin Alugas bottles fitted on our new moho ,,, I should have listened, it's useless when used with bottles.Yes there is .. our previous moho had one fitted by Autogas 2000 .. a series of nine leds not perfect but very close to accurate.
Thanks in advance.
Richard
Mine worked ok with the Alugas bottles in the locker. I had one readout and used only one of the two sensors and simply connected it on to whichever bottle I was using. Had to be careful to rotate the sensor around a bit as it was seated as it was easy to stick it on full or empty due to the orientation of the magnets.As a matter of interest maybe to others ,, Against the better advice of Autogas, I requested the same led system to be fitted to twin Alugas bottles fitted on our new moho ,,, I should have listened, it's useless when used with bottles.
That's interesting David, I shall have a look sometime to see what I can do. I have two of the 14Kg bottles which leave so little space above to get hands in to move anything .. the bottles do have upward facing gauges but impossible to read due to lack of space and pipework.Mine worked ok with the Alugas bottles in the locker. I had one readout and used only one of the two sensors and simply connected it on to whichever bottle I was using. Had to be careful to rotate the sensor around a bit as it was seated as it was easy to stick it on full or empty due to the orientation of the magnets.
Hi Brian... I had a few issues (also 14kg ones from @Theonlysue ) which only just fitted, like yours. As each bottle already had the sender unit I simply wired a single wire to the cab, earth8ng the other on the earth point and as I said, swap the sender unit over as needed. I only secure the sender with a single machine screw as it is easier. I found that the gauges could stick either full or empty unless wiggled a bit to make sure they move when fitting. Occasionally stick as well but a quick shove on the bottle cures that. Not perfect but it worked for me. CheersThat's interesting David, I shall have a look sometime to see what I can do. I have two of the 14Kg bottles which leave so little space above to get hands in to move anything .. the bottles do have upward facing gauges but impossible to read due to lack of space and pipework.
Our underslung tank fit from Autogas 2000 has the remote LED gauge and it's not even close to accurate. The last red led lights up at a shade under half a tank. We raised the issue with them but they said it's a sealed system and there was nothing they could do to adjust it. I suppose we have plenty of warning but I would prefer have an indication of a few day gas left rather than a few weeks.Yes there is .. our previous moho had one fitted by Autogas 2000 .. a series of nine leds not perfect but very close to accurate.
Sounds like a slightly careless installation to me..... the rotation angle of the fixed tank has to be fairly precise for the gauge and 80% cut off float to work properly, so I am told.Our underslung tank fit from Autogas 2000 has the remote LED gauge and it's not even close to accurate. The last red led lights up at a shade under half a tank. We raised the issue with them but they said it's a sealed system and there was nothing they could do to adjust it. I suppose we have plenty of warning but I would prefer have an indication of a few day gas left rather than a few weeks.
