Has anyone used injector lubricant such as ic12 to clean up a regulator?
Yes, I believe it is but was never a problem on the old truma regs. As I said, instead of fixing the reg problem they masked it with a filter.Thought it was something to do with oil in LPG I will have a look for other threads.
Thanks for your advice.
Have you also got the union adaptor for the right hand connection Jock.I'm still on one of these, fitted almost 20 x years ago...........
..............and although it is still going strong, I do have a new regulator on standby, should this one fail. There are no filters in the system that I am aware of, and it is solid pipe all the way from the bulk tank, so no worries about the leaching of oils or residue from rubber hoses.
Cheers,
Jock.
P.S. I should have said, that I am unable to source the exact replacement new, so have chosen one of these.
Ha ha, well spotted there John. No, not yet but will do.Have you also got the union adaptor for the right hand connection Jock.
That sounds more like a problem with the heater than a failing regulator. I certainly wouldn't try using any kind of cleaning fluid in a gas regulator, you can't be certain you got it all out and you don't know what it might do it if gets to the burner of an appliance. The oil is present in all lpg, the problem with the regulators is the oil, if it gets into the reg, contaminated the diaphragm causing it to swell. Cleaning the oil out will not fix the swollen diaphragm.There was a problem with the regulator shortly after purchasing the van and had to get it replaced under warranty. Now the heater switches off after it has been on full heat. Thought i’d Try cleaning regulator with injector cleaner. Sounds like Truma need to up their game.
Thanks for your information.
Agreed John, but a visit with the MH and the regulator, to a respected Auto LPG Converter and Installer near us, proved to be fruitless.Sods law it'll fail when you can get one.
Ha Ha, and how old is yours Richard?When I reinstated my bulk tank I thought it was best to change my one of those. If you want it for spares I still have it
Thanks for that Dave think,it is good advice.That sounds more like a problem with the heater than a failing regulator. I certainly wouldn't try using any kind of cleaning fluid in a gas regulator, you can't be certain you got it all out and you don't know what it might do it if gets to the burner of an appliance. The oil is present in all lpg, the problem with the regulators is the oil, if it gets into the reg, contaminated the diaphragm causing it to swell. Cleaning the oil out will not fix the swollen diaphragm.
D.
