Refitting skylight wrong way round
Chapel St Leonards, UK
Fiat ducato pvc self
Since 2017
Since buying our Rimor in April the roof has leaked around the skylight. I removed a badly fitted TV aerial at drax and cured most of the problem. Unfortunately an annoying drip remains when parked level. The water flows down the dome shaped roof for the overcab bed and pools about an inch deep against the skylight. Today I have removed the skylight and discovered the water is getting in through the boltholes that hold the hinges. I can reseal and refit but the sealer will only be 1mm or so thick and the thread of the bolts will still act as a canal for the water. The other side has no such holes so much less chance of leaking. Is there any reason not to fit the unit so that it opens at the front instead of the rear?
What type of sealant are you using?
If you use non setting butyl mastic you can double it up and create a thicker seal .
Sounds to me like a case for Captain Tolley's Creeping Crack Cure.
https://www.ebay.co.uk/itm/20621430...pid=5339023013&customid=&toolid=10001&mkevt=1
Also, instead of trying to build a wall of gloop round the front of the skylight, why not stick down a ready-made 'wall' comprising a strip of plastic stuff from the strips of plastic stuff department at B&Q or similar retailer, or the thisllbeusefullater section at the back of your shed. Electrical conduit comes to mind. Make a 'U' shape if essenial but I think just going a bit wider than the skylight would probs be enough.
And definitely do not put the hinge at the back & opening at the front for reasons given above plus what if you want to drive with it slightly open due to no aircon?
If I could have been sure where the water was coming in Captain Tolley's would have been ideal. Indeed I wish I had tried it before dismantling it. Not sure if it bonds to different types of sealant will have to investigate. Also how does it dry? Is it hard or permanently pliable?
Despite others recommendations, I have never achieved success with Captain Tolley's.
I must be doing something wrong? 😢
Still at the cleaning out twenty years of crap sealant etc stage. Will visit Leroy Merlin or feu vert later to see what I can get. Most on here seems to recommend sikaflex.
Sikaflex is great stuff but hasn't got the flexibility of non setting mastic and once you have used Sikaflex it's impossible to get the stuff off cleanly to reapply if you need to seal it again.
I think I need to use something that sets possibly even silicone when I reassemble the hinge brackets. I then need a more flexible non setting sealant to bed the whole thing on. Maybe then belt and braces another smear around the outside. This is the awkward part as you can't get at the long edge where the hinges are without removing the "glass"!
I had a similar issue in the past and used butyl tape over lapped into the hole then a second layer around the skylight and squeezed it together with quick clamps it never leaked again even when pooled around it, imo Sikaflex is a brilliant product but this is not the best application for it, butyl tape has a softer base and remains sticky, as im sure you are finding out whilst removing it, get the prep right and clean with a good panel wipe and you will have no problems. (y)
I would use sika 710 not 522. It is a mastic rather than a glue. You can get it in a rolled up strip or in the usual applicator for a gin, or even a gun. I might also consider an eternabond strip over the fixings. It also seals with a layer of mastic and is doing a great job on my roof. That said, being a belt and braces man, since this is a long term issue, I'd build a small plastic diverter wall glued around the front and sides of the vent
This sounds the best way of rebedding the whole thing. It is virtually impossible to get at the leading edge after because of the design of the hinges. That was why I wondered if it was practical to fit other way around. There was no tape to remove just poorly applied sealant of various descriptions from previous installation/repair. Will see if butyl tape is easily available here.
I think the plastic diverter is a necessity given the size of lake Ontario (other names available) that forms due to years of roof sag.
Have you considered building up the roof with some fibreglass and filler restoring the flatness, or even a gentle slope of your choosing in the direction of the side of the roof. It doesn't have to be a perfect body work job since no one sees it!! As long as it is reasonably smooth with a reasonable coat of paint
Before I purchased my current van a PVC Ducato the big wider skylight has been fitted the wrong way round, opens to the front not the rear.
No issues whatsoever so ever.
Hi Dennis use Stixall to seal it.
You have thrown me saying the hinges are bolted on? Do you mean the pins that usually hold the clear top( part1)and cream bottom together? (Part2)
The inside (part3) is nothing to do with it leaking😁
Part 2 should have a upstanding about 1/12 ins /30mm deep so no water should get over that. The bolts/pins are on the outsides so again it shouldn’t leak inside. I know it’s an older van so a pic would be helpful 👍 Has it got a winding Handel or simply a push up bar? I have known the winding to leak on some Hymers but that wasn’t really the Handel more it not been sealed properly to the bodywork. I can have a look at it for you when you’re back in the country ?
@Boldy With regard to fitting the wrong way is this what your rear catches are like ?
If so I would be very dubious about relying on them to stop the skylight flying open if you refit the skylight the wrong way around.
I think if the van was worth it and I knew someone to do it properly this would be worth considering. I could just install a prop on the inside and give Steph somewhere to practice her pole dancing skills but I think it would be in the way.😂
View attachment 1272559@Boldy With regard to fitting the wrong way is this what your rear catches are like ?
Ours is the one with the crank handle and when closed is hooked down quite firmly. But I think I shall try and get a good seal the right way round before trying the reversal.
The hinge is fastened to part 2 via a bolt through into channel nut type nut. We are fortunate here(?) that we get Saharan rain so the route of water is plain to see as it is like putting food colouring in when trying to trace a leak.
Although the holes must be minute the water is definitely getting in via the hinge bracket/channel nut arrangement. There are four of them.
In my experience it gets anywhere & sticks to anything - rubber windscreen surrounds, painted & bare metal, grp, ceramic tiles... just give it a gap and I'll crawl in & hide.
Bonding isn't an issue because it's not for sticking things together but once it's dry you'll need a scalpel to get it off so keep a rag handy & immediately wipe it off if you get any where you didn't want it.
Dries almost clear but with very, very slight yellowing just detectable against white tiles. Wouldn't call it pliable though - it's more for cracks where pliance doesn't happen. Not sure whether pliance is a real word but if it wasn't it is now.
Since you already dismantled I'd reassemble in your chosen manner but knowing that this might usefully be applied to the done job for extra security.
Sorry to hear that - wonder whether you were trying to seal gaps above it's pay grade?
Like sealing round my bath at home between the bath & the tiled wall - there had to be silicon sealant first for gap-filling but Captain Tolley dealt with where the sealant had not been properly bedded into the between-tiles grouting..
Upvote 1
Although the holes must be minute the water is definitely getting in via the hinge bracket/channel nut arrangement. There are four of theView attachment 1272612
Can't really visualise what's what without a wider angle view for context but my first reaction is to drown it in Tolly's, reassemble & see what happens.
My suggestion for a permanent solution would be to have a sub frame made around an inch or more in thickness.
Fit that under the skylight and bobs your aunty 😊
For context this is the frame with the glass detached. There are 4 hinges along the left side one is installed temporarily to take the previous photos. I'm surprised others don't leak in the same way but maybe the positioning by Rimor leading to the formation of the lake makes it worse.
Whilst that is a good idea I don't think the fixings between the above and below roof parts would be long enough leading to an unsightly gap.
Yes I can see that but that gap could be got over with thin and flexible plastic type stuff or similar.
Ok Dennis take the bolts out - clean and then seal all around and in bolt holes then seal all around and re fix onto the roof👍 Use the Stixall I mentioned 😉
