Refillable gas foreign adaptors
Norwich
Carthago A class
Since 2014
Off to France soon and will need to fill up on GPL while over there. How tight should the adaptors be screwed into the existing (bayonet) fitting? Long time since I filled up abroad and I seem to remember the fitting leaked last time I used it. I thought the ribber "O" ring had hardened with the temperature of the liquid gas and leaked. Wasn't in much of a position to do a detailed analysis as I just wanted to disconnect before something blew up!
Good hand tight, I always take a cloth to get a grip plus it helps undoing once filled as the cold gas seems to seal it on more.
Yep hand tight, when filling up in Belgium I always have a pair of water pump pliers handy as with their screw on connector a couple of times I've not been able to get it off my adaptor. I think Germany & Austria use the same fitting.
Hand tight, i've had no leaks or difficulty removing, but be aware that the adaptor may be cold so maybe use a glove which will also give extra purchase when removing.
Thanks all. I usually use gloves. Guess I didn’t tighten it enough before.
