Red light on panel
Griff097
Cardiff, UK
Rollerteam 685
I've been googling but can't find the answer to this, not sure if this light is to do with hook up as we never hook up?
At the same time we noticed the 12v socket by the TV point and the bathroom lights won't work.
That looks like a switch on/off button does the Center red light turn green if you switch on the lit power button?🤔
Sorry I’m not familiar with that type of switch panel I’m sure someone will be along soon who is🤔?
Another thought is have the trips dropped on your consumer unit?
I haven't checked those yet, have to find them.
I've tried turning the panel off and back on to reset, but the same.
The consumer unit should be somewhere near the power hook up point I would think🤔
Edit : not relevant
Googling that control panel says that light is illuminated when a fuse has blown - which may also explain your lack of 12v in certain areas. Not sure where the habitation fuses are on that model. I'll google some more if I get a chance.
I found the info on the control panel here
Bit more google-fu - in the same link above shows the fuses are underneath the dinette seating on the 740, can't find anything about the 685 but at least it shows what you're looking for
Found one blown fuse and light still on, in book it refers to a "diverter Ne185 fuse" no idea what that is, still looking.
According to this the NE 185 is the fuse board itself,might be worth giving them a ring.
Did the fuse blow again immediately? Possible short somewhere if so. But if the fuse you replaced is still good, then it's confusing. Is it possible to trace back the wires from the tv socket and see where it's fused (assuming it still has no 12v)?
Worked it out the new fuse has been carried as a spare for a long time and the pins weren't clean enough!
I’ve got exactly same problem have you located the fuse many thanks
