red flashing lights on gas operation ? (1 Viewer)
Jan 27, 2018
830
1,704
Aberdeenshire
low profile
When heating is on gas operation a red flashing lights comes on but only when the fan is on "boost" . The instruction books tells me this is indicating a low battery but I have a 140 ah new battery which is showing 12.4v.
The heating is working fine but the flashing lights concerns me.
Does anyone have any ideas ?
PS. I'm not a technical sort of chap so hope I've explained this adequately.
funflair
19,339
30,205
Guisborough
MORELO palace
since 2012
Try putting a few more amps into the battery and then you might answer your own question, 12.4 isn't very high.
Martin
Geistguy
Jan 27, 2018
830
1,704
Aberdeenshire
low profile
Thanks for that, I will try the heating on gas when on hook up and see what happens. As I said I'm not very technical and I did think 12.4 was quite good. Never to old to learn. :)
Jan 28, 2008
10,116
18,382
Dovercourt, Harwich, UK
Renalt burstner
7 years campers before that
check voltage at the heater when its working poor connections or undersized cable could be the cause also what heater do you have ?
Geistguy
Jan 27, 2018
830
1,704
Aberdeenshire
low profile
The heater is a Truma circa 2008, not sure which model though.
