Recommendation for hab door fix (1 Viewer)
Hils and Glenns
1,372
60,865
N Yorks
Hymer B 674
Since 2015
The hab door on our hymer has got cluncky to close and sticks a bit when opening. I think it may need rehanging. Can anyone recommend someone in North Yorkshire who can fix it please?
Feb 22, 2011
9,113
17,767
Newcastle under Lyme
Hymer B544 A Class
Since 2015
Have you tried a spray with silicone lubricant ? Or could it be the hinges worn and need replacing ?
Hils and Glenns
Hils and Glenns
1,372
60,865
N Yorks
Hymer B 674
Since 2015
Not sure what the problem is which is why I think it needs someone who knows what they're doing.:confused:
Jaws
23,762
74,766
Thetford Norfolk
C class, Chieftain
since 2006 ( I think ! )
Before spending your hard earned a quick wipe of the rubber door seal with a rag covered in WD40 or better still, one of the silicone based sprays like GT85 may well cure the issue
Jaws
23,762
74,766
Thetford Norfolk
C class, Chieftain
Paul and Kate
2,089
11,053
Stoke on trent
Auto sleeper Warwick
Since 2015
It could be your striker plates.
Untighten the screws and they move up or down to suit.
Ours was the same when we picked it up.
It was on a bailey though
DuxDeluxe
14,554
74,651
Planet Zog
A woosh bang van
since 2008
Yes, we fixed the door on another funster's van by adjusting the striker plate
glastry
368
304
northern ireland and portugal
a class s550
Hils and Glen, First check that all the hinge screws are tight!
The striker plate you can usually see at a glance if there is a problem.
After the above lubricate the hinges and the door lock.
7
7735
Wd40 rots rubber use a silicone spray.
Spongy
Lenny HB
50,206
138,451
On the coast in West Sussex
Hymer B678 DL
If it is the Hartal door with the three striker pins. Loosen off the locking screw and wind the pins in or out to adjust. You need to get them set just right as the body expands/contracts 2-3mm with temperature fluctuations.
Aug 27, 2014
1,875
3,315
Shropshire
McLouis Tandy 640+
Since 2014
Not sure on Hymer, but on mine the hinges had started to seize on the pins, more than a spray with WD40 could cure. It was a case of working one hinge at a time, slacken the fixings off the frame and door, gently persuade the 2 halves of the hinge to separate with a dead blow hammer and a length of softwood as a sacrificial drift, clean the pins up, good smear of grease and back together again, then move onto the next. Has worked fine ever since.
Hils and Glenns
Hils and Glenns
1,372
60,865
N Yorks
Hymer B 674
Since 2015
Thanks for all your suggestions.
We've done this and its much improved. We'll see how we go on the next trip.
